Tuya 4-Button Scene TS0044 via Zigbee (MQTT trigger version)
This is a reworked version of the blueprint for Tuya 4-Button Scene Remotes (like TS0044), using MQTT triggers instead of legacy action entities.
blueprint:
  domain: automation
  name: Moes/Tuya 4-Button Scene Switch by Dameq
  description: Moes/Tuya 4-Button Scene via Zigbee (MQTT trigger version).
  input:
    input_device:
      description: Select the Moes/Tuya 4-Button Scene Switch device
      selector:
        device:
          integration: mqtt
          manufacturer: Tuya
          multiple: false
    button_one_short_press:
      name: Single Press - Button 1
      description: Action to run on button 1 (top-left) single press
      default: []
      selector:
        action: {}
    button_one_double_press:
      name: Double Press - Button 1
      description: Action to run on button 1 (top-left) double press
      default: []
      selector:
        action: {}
    button_one_long_press:
      name: Long Press - Button 1
      description: Action to run on button 1 (top-left) long press
      default: []
      selector:
        action: {}
    button_two_short_press:
      name: Single Press - Button 2
      description: Action to run on button 2 (top-right) single press
      default: []
      selector:
        action: {}
    button_two_double_press:
      name: Double Press - Button 2
      description: Action to run on button 2 (top-right) double press
      default: []
      selector:
        action: {}
    button_two_long_press:
      name: Long Press - Button 2
      description: Action to run on button 2 (top-right) long press
      default: []
      selector:
        action: {}
    button_three_short_press:
      name: Single Press - Button 3
      description: Action to run on button 3 (lower-left) single press
      default: []
      selector:
        action: {}
    button_three_double_press:
      name: Double Press - Button 3
      description: Action to run on button 3 (lower-left) double press
      default: []
      selector:
        action: {}
    button_three_long_press:
      name: Long Press - Button 3
      description: Action to run on button 3 (lower-left) long press
      default: []
      selector:
        action: {}
    button_four_short_press:
      name: Single Press - Button 4
      description: Action to run on button 4 (lower-right) single press
      default: []
      selector:
        action: {}
    button_four_double_press:
      name: Double Press - Button 4
      description: Action to run on button 4 (lower-right) double press
      default: []
      selector:
        action: {}
    button_four_long_press:
      name: Long Press - Button 4
      description: Action to run on button 4 (lower-right) long press
      default: []
      selector:
        action: {}
mode: parallel
max_exceeded: silent
  - id: button_one_short_event
    device_id: !input input_device
    domain: mqtt
    type: action
    subtype: 1_single
    trigger: device
  - id: button_one_double_event
    domain: mqtt
    type: action
    subtype: 1_double
    trigger: device
  - id: button_one_long_event
    domain: mqtt
    type: action
    subtype: 1_hold
    trigger: device
  - id: button_two_short_event
    domain: mqtt
    type: action
    subtype: 2_single
    trigger: device
  - id: button_two_double_event
    domain: mqtt
    type: action
    subtype: 2_double
    trigger: device
  - id: button_two_long_event
    domain: mqtt
    type: action
    subtype: 2_hold
    trigger: device
  - id: button_three_short_event
    domain: mqtt
    type: action
    subtype: 3_single
    trigger: device
  - id: button_three_double_event
    domain: mqtt
    type: action
    subtype: 3_double
    trigger: device
  - id: button_three_long_event
    domain: mqtt
    type: action
    subtype: 3_hold
    trigger: device
  - id: button_four_short_event
    domain: mqtt
    type: action
    subtype: 4_single
    trigger: device
  - id: button_four_double_event
    domain: mqtt
    type: action
    subtype: 4_double
    trigger: device
  - id: button_four_long_event
    domain: mqtt
    type: action
    subtype: 4_hold
    trigger: device
- variables:
    command: "{{ trigger.id }}"
- choose:
  - conditions:
    - "{{ command == 'button_one_short_event' }}"
    sequence: !input "button_one_short_press"
  - conditions:
    - "{{ command == 'button_one_double_event' }}"
    sequence: !input "button_one_double_press"
  - conditions:
    - "{{ command == 'button_one_long_event' }}"
    sequence: !input "button_one_long_press"
  - conditions:
    - "{{ command == 'button_two_short_event' }}"
    sequence: !input "button_two_short_press"
  - conditions:
    - "{{ command == 'button_two_double_event' }}"
    sequence: !input "button_two_double_press"
  - conditions:
    - "{{ command == 'button_two_long_event' }}"
    sequence: !input "button_two_long_press"
  - conditions:
    - "{{ command == 'button_three_short_event' }}"
    sequence: !input "button_three_short_press"
  - conditions:
    - "{{ command == 'button_three_double_event' }}"
    sequence: !input "button_three_double_press"
  - conditions:
    - "{{ command == 'button_three_long_event' }}"
    sequence: !input "button_three_long_press"
  - conditions:
    - "{{ command == 'button_four_short_event' }}"
    sequence: !input "button_four_short_press"
  - conditions:
    - "{{ command == 'button_four_double_event' }}"
    sequence: !input "button_four_double_press"
  - conditions:
    - "{{ command == 'button_four_long_event' }}"
    sequence: !input "button_four_long_press"
Hello dameq1,
Adding a MY link for this Blueprint to your top post would help them a lot.
Here is the link to make that.
Create a link – My Home Assistant
Hello @dameq1
Can you please explain how to implement this blueprint in HA?
Currently having issues with my 4 way switch when moving from ZHA to MQTT.
The switch sees the actions but will not make entities from it.
P.s. have not much experience with programming… at least yet…
Thank you in advance!
