Description:
It would be great if the manual_feed command could be added for the Tuya PLAF203 Camera Feeder in Home Assistant.
Proposed Feature:
- Implement the
manual_feedcommand for the PLAF203 Camera Feeder. - The command should accept a number between 1 and 50, representing the number of portions to be dispensed (similar to the functionality in the device’s original app).
Use Case:
- This feature would enable users to manually trigger portion dispensing directly from Home Assistant, enhancing automation possibilities.
- In another smart home system (ioBroker), a Tuya integration already allows executing the
manual_feedcommand with a portion count, proving that this functionality is accessible via Tuya’s API.
Implementation Suggestion:
- Extend the existing Tuya integration to support the
manual_feedcommand for the PLAF203 Camera Feeder. - Ensure the command can take a numeric input (1-50) to specify portion size.
Would love to see this feature implemented!
