Tuya ampoule RGB
I’m all new to the Home Assistant
I put my Tuya plugs and bulb
I can turn on or off and vary the brightness of the lamp but not change the RGB color
How to do ?
Thank you for your help
Bonjour,
Je suis tous nouveau dans le Home Assistant
J’ai mis mes prises et ampoule Tuya
Je peut allumer ou éteindre et varié la luminosité de la lampe mais pas changer la couleur RGB
Comment faire ?
Merci de votre aide
That’s probably because it may not yet be supported (not double checked the code)
See if you can reflash with tasmota or espurna.
This not only will give you more control over them, it will also mean you won’t rely on the cloud for them to work and you won’t send your data to China
(PS. Pas de francais ici, tout se fait en anglais pour que tout le monde puisse en profiter :wink: )
it is a logicom home bubbly bulb, it does not pass a cloud china, but I declared the tuya, I see everything I arrive has controlled everything, the bulb I come on and turn on to control the level of light power but not color, share the software yes yes share Alexa too
No one to help with this problem
You have already had some help. But please don’t bump your post until 24 hours have passed
Also if your device is a tuya device it goes through the cloud. Not sure where tuyas servers are, but likely China.
