Tuya based heatpump does not show entities in Home Assistant
Hi there,
I recently added a tuya based heatpump to Hassio, but it won’t show any of it’s parameters that show in the Tuya/Smartlife app itself.
It only shows a simple Switch Entity, that turns the heatpump on and off.
I’ve fidled around with LocalTuya, Tuya Local and got some of the entities visible. But no more of the so calles DP’s.
Can someone help me with ways to read the parameters and maybe even gain some controls
The heatpump stats are:
PowerWorld PW58330 Heatpump
products:
  • id: “74jzzoqr2ghxyu1p”
    name: “My house heat pump”
Thanks in advance!
I’ve managed to get some of the parameter_groups from the Tuya API into HA.
Some of the entities show RAW data. Is there a way to let Home Assistant translate this into readable information?
Hey @Nwb ,
I have exactly the same problem - in the Life app all the information and all the settings are there and work, in HA there is only a switch. Have you been able to find out anything yet? Maybe we can get started together. Best regards,
Holger
