I just received an iH-F8260 IR-Blaster. Zigbee2mqtt pair with it, but it is an unrecognizable device. Zigbee is completely new to me. What’s my options here?
Questions…
Have you got a zigbee co-ordinator? This is usually a USB dongle - there’s a list in the ZHA docs mentioned below.
Have you installed an integration? The main options are ZHA…
…and z2m:
Do you have any other zigbee devices? Zigbee is a mesh network in which a swarm of router devices (mains powered, eg lights, smart plugs and sockets) relay messages to end devices like your IR blaster (usually battery powered). It isn’t a broadcast system like wi-fi - without router devices your IR blaster probably won’t be much use.
Yes, i have a coordinator (Sonoff USB v. E), running Z2M, and multiple other Zigbee devices.
Hello, is there anything new about that topic?
I’ve the same problem. Find no way to get IR Codes learned.
Hi, same problem, here, I was somehow able to learn a code (I doubt it’s correct), but I can’t send the code, tried changing the post message with no results, nothing is emitted from the ir (checked with the cell camera)
