Hi. I’m using tuya home assistant integration with this tuya device Robert Smart Wi-Fi LED color changing light bulb. I’m using the usual wall switch to turn it on/off, so the device is completely off power in the off state. When I turn the bulb on and off several times, it gets reset and enters this on-off-on-off… blinking state.
Is there a tuya bulb that doesn’t show this behavior and can it be fixed?
That is usually the way to reset a bulb since it doesn’t have any buttons.
Why do you do this? Why do you cut the power to a smart bulb?
Well, because I want to turn the light on or off. I would expect for a device get reset if I’d do this on/off within some small period (seconds), but this device gets reset even if I turn it on after several minutes or hours. I have another devices - smart Z-wave bulbs with the same principle of reset with power cycling. Now I’ve used them for years already with no such issue observed.
