I am brand new to this community and Home Assistant. I am quickly learning and seem to have everything under control with the exception of my Honeywell thermostat and my Tuya integrated camera. So far I have not tried too much because I’m still pretty much wet behind the ears.
here is the log with tons of errors. If anyone could show me what I missed I would greatly appreciate it. I apologize if its uncool to post logs like this, however I don’t see a include log button nor am I used to posting in forums.
And just so you know how new I am I started setting it up a few days ago and made so many mistakes I reset and reformatted everything and started with all fresh downloads. The camera never worked right but in my last install the thermostat worked fine thru TCC (us).
EDIT: No idea what did it, however, since a rest, deleting the integration for the thermostat and then adding it again, it now works as expected.
Still no camera feed and still getting previews on card updated every few seconds.
2022-06-08 10:23:16 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2022-06-08 10:25:45 ERROR (SyncWorker_2) [somecomfort] API Rate Limited.
2022-06-08 10:25:45 ERROR (MainThread) [homeassistant.config_entries] Error setting up entry honeywell for honeywell
File “/usr/src/homeassistant/homeassistant/config_entries.py”, line 339, in async_setup
result = await component.async_setup_entry(hass, self)
File “/usr/src/homeassistant/homeassistant/components/honeywell/init.py”, line 54, in async_setup_entry
client = await hass.async_add_executor_job(
File “/usr/local/lib/python3.9/concurrent/futures/thread.py”, line 58, in run
result = self.fn(self.args, **self.kwargs)
File “/usr/src/homeassistant/homeassistant/components/honeywell/init.py”, line 105, in get_somecomfort_client
return somecomfort.SomeComfort(username, password)
File “/usr/local/lib/python3.9/site-packages/somecomfort/client.py”, line 395, in init
self._discover()
File “/usr/local/lib/python3.9/site-packages/somecomfort/client.py”, line 51, in wrapper
return fn(args, **kwargs)
File “/usr/local/lib/python3.9/site-packages/somecomfort/client.py”, line 527, in _discover
for raw_location in raw_locations:
TypeError: ‘NoneType’ object is not iterable
2022-06-08 10:26:48 ERROR (MainThread) [frontend.js.latest.202206010] http://10.0.0.178:8123/lovelace/default_view:0:0 Uncaught
2022-06-08 10:34:15 ERROR (stream_worker) [homeassistant.components.stream.stream.camera.camera] Error from stream worker: Stream ended; no additional packets
2022-06-08 10:34:25 ERROR (stream_worker) [homeassistant.components.stream.stream.camera.camera] Error from stream worker: Error opening stream (HTTP_NOT_FOUND, Server returned 404 Not Found) rtsps://:@aws-wework6.tuyaus.com:443/v1/eb6c5107b24edc31d6a6fe/cagb23uf95gpue94dk70tDwtLtM0DM4J?signInfo=oFuDgpWuLfZ6PvtiQYH%2B9AAYnjhTxc3fD2fG8WuGFIFbGSvJawiSyDFun9qhwL%2BZKL4rfSrAZM4DVcIZSD13doAScQujyAYtbSD2t1vUeu%2Fg2Go56pz4%2BaGBcOkWNojBV8dhhPWmbbPnjVsaflPy09PfDVA5S1JEn8K11xzYOeE%3D
2022-06-08 10:34:46 ERROR (stream_worker) [homeassistant.components.stream.stream.camera.camera] Error from stream worker: Error opening stream (HTTP_NOT_FOUND, Server returned 404 Not Found) rtsps://:@aws-wework6.tuyaus.com:443/v1/eb6c5107b24edc31d6a6fe/cagb23uf95gpue94dk70tDwtLtM0DM4J?signInfo=oFuDgpWuLfZ6PvtiQYH%2B9AAYnjhTxc3fD2fG8WuGFIFbGSvJawiSyDFun9qhwL%2BZKL4rfSrAZM4DVcIZSD13doAScQujyAYtbSD2t1vUeu%2Fg2Go56pz4%2BaGBcOkWNojBV8dhhPWmbbPnjVsaflPy09PfDVA5S1JEn8K11xzYOeE%3D
2022-06-08 10:35:17 ERROR (stream_worker) [homeassistant.components.stream.stream.camera.camera] Error from stream worker: Error opening stream (HTTP_NOT_FOUND, Server returned 404 Not Found) rtsps://:@aws-wework6.tuyaus.com:443/v1/eb6c5107b24edc31d6a6fe/cagb23uf95gpue94dk70tDwtLtM0DM4J?signInfo=oFuDgpWuLfZ6PvtiQYH%2B9AAYnjhTxc3fD2fG8WuGFIFbGSvJawiSyDFun9qhwL%2BZKL4rfSrAZM4DVcIZSD13doAScQujyAYtbSD2t1vUeu%2Fg2Go56pz4%2BaGBcOkWNojBV8dhhPWmbbPnjVsaflPy09PfDVA5S1JEn8K11xzYOeE%3D
2022-06-08 10:35:57 ERROR (stream_worker) [homeassistant.components.stream.stream.camera.camera] Error from stream worker: Error opening stream (HTTP_NOT_FOUND, Server returned 404 Not Found) rtsps://:@aws-wework6.tuyaus.com:443/v1/eb6c5107b24edc31d6a6fe/cagb23uf95gpue94dk70tDwtLtM0DM4J?signInfo=oFuDgpWuLfZ6PvtiQYH%2B9AAYnjhTxc3fD2fG8WuGFIFbGSvJawiSyDFun9qhwL%2BZKL4rfSrAZM4DVcIZSD13doAScQujyAYtbSD2t1vUeu%2Fg2Go56pz4%2BaGBcOkWNojBV8dhhPWmbbPnjVsaflPy09PfDVA5S1JEn8K11xzYOeE%3D
2022-06-08 10:36:48 ERROR (stream_worker) [homeassistant.components.stream.stream.camera.camera] Error from stream worker: Error opening stream (HTTP_NOT_FOUND, Server returned 404 Not Found) rtsps://:@aws-wework6.tuyaus.com:443/v1/eb6c5107b24edc31d6a6fe/cagb23uf95gpue94dk70tDwtLtM0DM4J?signInfo=oFuDgpWuLfZ6PvtiQYH%2B9AAYnjhTxc3fD2fG8WuGFIFbGSvJawiSyDFun9qhwL%2BZKL4rfSrAZM4DVcIZSD13doAScQujyAYtbSD2t1vUeu%2Fg2Go56pz4%2BaGBcOkWNojBV8dhhPWmbbPnjVsaflPy09PfDVA5S1JEn8K11xzYOeE%3D
2022-06-08 10:37:48 ERROR (stream_worker) [homeassistant.components.stream.stream.camera.camera] Error from stream worker: Error opening stream (HTTP_NOT_FOUND, Server returned 404 Not Found) rtsps://:@aws-wework6.tuyaus.com:443/v1/eb6c5107b24edc31d6a6fe/cagb23uf95gpue94dk70tDwtLtM0DM4J?signInfo=oFuDgpWuLfZ6PvtiQYH%2B9AAYnjhTxc3fD2fG8WuGFIFbGSvJawiSyDFun9qhwL%2BZKL4rfSrAZM4DVcIZSD13doAScQujyAYtbSD2t1vUeu%2Fg2Go56pz4%2BaGBcOkWNojBV8dhhPWmbbPnjVsaflPy09PfDVA5S1JEn8K11xzYOeE%3D
2022-06-08 10:38:59 ERROR (stream_worker) [homeassistant.components.stream.stream.camera.camera] Error from stream worker: Error opening stream (HTTP_NOT_FOUND, Server returned 404 Not Found) rtsps://:@aws-wework6.tuyaus.com:443/v1/eb6c5107b24edc31d6a6fe/cagb23uf95gpue94dk70tDwtLtM0DM4J?signInfo=oFuDgpWuLfZ6PvtiQYH%2B9AAYnjhTxc3fD2fG8WuGFIFbGSvJawiSyDFun9qhwL%2BZKL4rfSrAZM4DVcIZSD13doAScQujyAYtbSD2t1vUeu%2Fg2Go56pz4%2BaGBcOkWNojBV8dhhPWmbbPnjVsaflPy09PfDVA5S1JEn8K11xzYOeE%3D
2022-06-08 10:39:45 ERROR (MainThread) [homeassistant.components.analytics] Timeout sending analytics to https://analytics-api.home-assistant.io/v1
2022-06-08 10:40:20 ERROR (stream_worker) [homeassistant.components.stream.stream.camera.camera] Error from stream worker: Error opening stream (HTTP_NOT_FOUND, Server returned 404 Not Found) rtsps://:@aws-wework6.tuyaus.com:443/v1/eb6c5107b24edc31d6a6fe/cagb23uf95gpue94dk70tDwtLtM0DM4J?signInfo=oFuDgpWuLfZ6PvtiQYH%2B9AAYnjhTxc3fD2fG8WuGFIFbGSvJawiSyDFun9qhwL%2BZKL4rfSrAZM4DVcIZSD13doAScQujyAYtbSD2t1vUeu%2Fg2Go56pz4%2BaGBcOkWNojBV8dhhPWmbbPnjVsaflPy09PfDVA5S1JEn8K11xzYOeE%3D
2022-06-08 10:41:50 ERROR (stream_worker) [homeassistant.components.stream.stream.camera.camera] Error from stream worker: Error opening stream (HTTP_NOT_FOUND, Server returned 404 Not Found) rtsps://:@aws-wework6.tuyaus.com:443/v1/eb6c5107b24edc31d6a6fe/cagb23uf95gpue94dk70tDwtLtM0DM4J?signInfo=oFuDgpWuLfZ6PvtiQYH%2B9AAYnjhTxc3fD2fG8WuGFIFbGSvJawiSyDFun9qhwL%2BZKL4rfSrAZM4DVcIZSD13doAScQujyAYtbSD2t1vUeu%2Fg2Go56pz4%2BaGBcOkWNojBV8dhhPWmbbPnjVsaflPy09PfDVA5S1JEn8K11xzYOeE%3D
2022-06-08 10:43:31 ERROR (stream_worker) [homeassistant.components.stream.stream.camera.camera] Error from stream worker: Error opening stream (HTTP_NOT_FOUND, Server returned 404 Not Found) rtsps://:@aws-wework6.tuyaus.com:443/v1/eb6c5107b24edc31d6a6fe/cagb23uf95gpue94dk70tDwtLtM0DM4J?signInfo=oFuDgpWuLfZ6PvtiQYH%2B9AAYnjhTxc3fD2fG8WuGFIFbGSvJawiSyDFun9qhwL%2BZKL4rfSrAZM4DVcIZSD13doAScQujyAYtbSD2t1vUeu%2Fg2Go56pz4%2BaGBcOkWNojBV8dhhPWmbbPnjVsaflPy09PfDVA5S1JEn8K11xzYOeE%3D
2022-06-08 10:45:22 ERROR (stream_worker) [homeassistant.components.stream.stream.camera.camera] Error from stream worker: Error opening stream (HTTP_NOT_FOUND, Server returned 404 Not Found) rtsps://:@aws-wework6.tuyaus.com:443/v1/eb6c5107b24edc31d6a6fe/cagb23uf95gpue94dk70tDwtLtM0DM4J?signInfo=oFuDgpWuLfZ6PvtiQYH%2B9AAYnjhTxc3fD2fG8WuGFIFbGSvJawiSyDFun9qhwL%2BZKL4rfSrAZM4DVcIZSD13doAScQujyAYtbSD2t1vUeu%2Fg2Go56pz4%2BaGBcOkWNojBV8dhhPWmbbPnjVsaflPy09PfDVA5S1JEn8K11xzYOeE%3D
2022-06-08 10:47:22 ERROR (stream_worker) [homeassistant.components.stream.stream.camera.camera] Error from stream worker: Error opening stream (HTTP_NOT_FOUND, Server returned 404 Not Found) rtsps://:@aws-wework6.tuyaus.com:443/v1/eb6c5107b24edc31d6a6fe/cagb23uf95gpue94dk70tDwtLtM0DM4J?signInfo=oFuDgpWuLfZ6PvtiQYH%2B9AAYnjhTxc3fD2fG8WuGFIFbGSvJawiSyDFun9qhwL%2BZKL4rfSrAZM4DVcIZSD13doAScQujyAYtbSD2t1vUeu%2Fg2Go56pz4%2BaGBcOkWNojBV8dhhPWmbbPnjVsaflPy09PfDVA5S1JEn8K11xzYOeE%3D
2022-06-08 10:49:10 ERROR (MainThread) [homeassistant.core] Error executing service: <ServiceCall media_player.turn_on (c:01G51WMJXT09TDZ80N0SWZ9ZA4): entity_id=[‘media_player.bedroom_tv’]>
File “/usr/src/homeassistant/homeassistant/core.py”, line 1722, in catch_exceptions
await coro_or_task
File “/usr/src/homeassistant/homeassistant/core.py”, line 1741, in _execute_service
await cast(Callable[[ServiceCall], Awaitable[None]], handler.job.target)(
File “/usr/src/homeassistant/homeassistant/helpers/entity_component.py”, line 204, in handle_service
await service.entity_service_call(
File “/usr/src/homeassistant/homeassistant/helpers/service.py”, line 680, in entity_service_call
future.result() # pop exception if have
File “/usr/src/homeassistant/homeassistant/helpers/entity.py”, line 964, in async_request_call
await coro
File “/usr/src/homeassistant/homeassistant/helpers/service.py”, line 717, in _handle_entity_call
await result
File “/usr/src/homeassistant/homeassistant/components/media_player/init.py”, line 688, in async_turn_on
await self.hass.async_add_executor_job(self.turn_on)
File “/usr/src/homeassistant/homeassistant/components/cast/media_player.py”, line 488, in turn_on
quick_play(self._chromecast, “default_media_receiver”, app_data)
File “/usr/local/lib/python3.9/site-packages/pychromecast/quick_play.py”, line 77, in quick_play
controller.quick_play(**data)
File “/usr/local/lib/python3.9/site-packages/pychromecast/controllers/media.py”, line 544, in quick_play
raise PyChromecastError()
pychromecast.error.PyChromecastError
2022-06-08 10:49:33 ERROR (stream_worker) [homeassistant.components.stream.stream.camera.camera] Error from stream worker: Error opening stream (HTTP_NOT_FOUND, Server returned 404 Not Found) rtsps://:@aws-wework6.tuyaus.com:443/v1/eb6c5107b24edc31d6a6fe/cagb23uf95gpue94dk70tDwtLtM0DM4J?signInfo=oFuDgpWuLfZ6PvtiQYH%2B9AAYnjhTxc3fD2fG8WuGFIFbGSvJawiSyDFun9qhwL%2BZKL4rfSrAZM4DVcIZSD13doAScQujyAYtbSD2t1vUeu%2Fg2Go56pz4%2BaGBcOkWNojBV8dhhPWmbbPnjVsaflPy09PfDVA5S1JEn8K11xzYOeE%3D
2022-06-08 10:51:54 ERROR (stream_worker) [homeassistant.components.stream.stream.camera.camera] Error from stream worker: Error opening stream (HTTP_NOT_FOUND, Server returned 404 Not Found) rtsps://:@aws-wework6.tuyaus.com:443/v1/eb6c5107b24edc31d6a6fe/cagb23uf95gpue94dk70tDwtLtM0DM4J?signInfo=oFuDgpWuLfZ6PvtiQYH%2B9AAYnjhTxc3fD2fG8WuGFIFbGSvJawiSyDFun9qhwL%2BZKL4rfSrAZM4DVcIZSD13doAScQujyAYtbSD2t1vUeu%2Fg2Go56pz4%2BaGBcOkWNojBV8dhhPWmbbPnjVsaflPy09PfDVA5S1JEn8K11xzYOeE%3D
2022-06-08 10:54:24 ERROR (stream_worker) [homeassistant.components.stream.stream.camera.camera] Error from stream worker: Error opening stream (HTTP_NOT_FOUND, Server returned 404 Not Found) rtsps://:@aws-wework6.tuyaus.com:443/v1/eb6c5107b24edc31d6a6fe/cagb23uf95gpue94dk70tDwtLtM0DM4J?signInfo=oFuDgpWuLfZ6PvtiQYH%2B9AAYnjhTxc3fD2fG8WuGFIFbGSvJawiSyDFun9qhwL%2BZKL4rfSrAZM4DVcIZSD13doAScQujyAYtbSD2t1vUeu%2Fg2Go56pz4%2BaGBcOkWNojBV8dhhPWmbbPnjVsaflPy09PfDVA5S1JEn8K11xzYOeE%3D
2022-06-08 10:57:05 ERROR (stream_worker) [homeassistant.components.stream.stream.camera.camera] Error from stream worker: Error opening stream (HTTP_NOT_FOUND, Server returned 404 Not Found) rtsps://:@aws-wework6.tuyaus.com:443/v1/eb6c5107b24edc31d6a6fe/cagb23uf95gpue94dk70tDwtLtM0DM4J?signInfo=oFuDgpWuLfZ6PvtiQYH%2B9AAYnjhTxc3fD2fG8WuGFIFbGSvJawiSyDFun9qhwL%2BZKL4rfSrAZM4DVcIZSD13doAScQujyAYtbSD2t1vUeu%2Fg2Go56pz4%2BaGBcOkWNojBV8dhhPWmbbPnjVsaflPy09PfDVA5S1JEn8K11xzYOeE%3D
2022-06-08 10:59:56 ERROR (stream_worker) [homeassistant.components.stream.stream.camera.camera] Error from stream worker: Error opening stream (HTTP_NOT_FOUND, Server returned 404 Not Found) rtsps://:@aws-wework6.tuyaus.com:443/v1/eb6c5107b24edc31d6a6fe/cagb23uf95gpue94dk70tDwtLtM0DM4J?signInfo=oFuDgpWuLfZ6PvtiQYH%2B9AAYnjhTxc3fD2fG8WuGFIFbGSvJawiSyDFun9qhwL%2BZKL4rfSrAZM4DVcIZSD13doAScQujyAYtbSD2t1vUeu%2Fg2Go56pz4%2BaGBcOkWNojBV8dhhPWmbbPnjVsaflPy09PfDVA5S1JEn8K11xzYOeE%3D
2022-06-08 11:02:56 ERROR (stream_worker) [homeassistant.components.stream.stream.camera.camera] Error from stream worker: Error opening stream (HTTP_NOT_FOUND, Server returned 404 Not Found) rtsps://:@aws-wework6.tuyaus.com:443/v1/eb6c5107b24edc31d6a6fe/cagb23uf95gpue94dk70tDwtLtM0DM4J?signInfo=oFuDgpWuLfZ6PvtiQYH%2B9AAYnjhTxc3fD2fG8WuGFIFbGSvJawiSyDFun9qhwL%2BZKL4rfSrAZM4DVcIZSD13doAScQujyAYtbSD2t1vUeu%2Fg2Go56pz4%2BaGBcOkWNojBV8dhhPWmbbPnjVsaflPy09PfDVA5S1JEn8K11xzYOeE%3D
2022-06-08 11:06:07 ERROR (stream_worker) [homeassistant.components.stream.stream.camera.camera] Error from stream worker: Error opening stream (HTTP_NOT_FOUND, Server returned 404 Not Found) rtsps://:@aws-wework6.tuyaus.com:443/v1/eb6c5107b24edc31d6a6fe/cagb23uf95gpue94dk70tDwtLtM0DM4J?signInfo=oFuDgpWuLfZ6PvtiQYH%2B9AAYnjhTxc3fD2fG8WuGFIFbGSvJawiSyDFun9qhwL%2BZKL4rfSrAZM4DVcIZSD13doAScQujyAYtbSD2t1vUeu%2Fg2Go56pz4%2BaGBcOkWNojBV8dhhPWmbbPnjVsaflPy09PfDVA5S1JEn8K11xzYOeE%3D
2022-06-08 11:09:28 ERROR (stream_worker) [homeassistant.components.stream.stream.camera.camera] Error from stream worker: Error opening stream (HTTP_NOT_FOUND, Server returned 404 Not Found) rtsps://:@aws-wework6.tuyaus.com:443/v1/eb6c5107b24edc31d6a6fe/cagb23uf95gpue94dk70tDwtLtM0DM4J?signInfo=oFuDgpWuLfZ6PvtiQYH%2B9AAYnjhTxc3fD2fG8WuGFIFbGSvJawiSyDFun9qhwL%2BZKL4rfSrAZM4DVcIZSD13doAScQujyAYtbSD2t1vUeu%2Fg2Go56pz4%2BaGBcOkWNojBV8dhhPWmbbPnjVsaflPy09PfDVA5S1JEn8K11xzYOeE%3D
2022-06-08 11:12:58 ERROR (stream_worker) [homeassistant.components.stream.stream.camera.camera] Error from stream worker: Error opening stream (HTTP_NOT_FOUND, Server returned 404 Not Found) rtsps://:@aws-wework6.tuyaus.com:443/v1/eb6c5107b24edc31d6a6fe/cagb23uf95gpue94dk70tDwtLtM0DM4J?signInfo=oFuDgpWuLfZ6PvtiQYH%2B9AAYnjhTxc3fD2fG8WuGFIFbGSvJawiSyDFun9qhwL%2BZKL4rfSrAZM4DVcIZSD13doAScQujyAYtbSD2t1vUeu%2Fg2Go56pz4%2BaGBcOkWNojBV8dhhPWmbbPnjVsaflPy09PfDVA5S1JEn8K11xzYOeE%3D
2022-06-08 11:16:40 ERROR (stream_worker) [homeassistant.components.stream.stream.camera.camera] Error from stream worker: Error opening stream (HTTP_NOT_FOUND, Server returned 404 Not Found) rtsps://:***@aws-wework6.tuyaus.com:443/v1/eb6c5107b24edc31d6a6fe/cagb23uf95gpue94dk70tDwtLtM0DM4J?signInfo=oFuDgpWuLfZ6PvtiQYH%2B9AAYnjhTxc3fD2fG8WuGFIFbGSvJawiSyDFun9qhwL%2BZKL4rfSrAZM4DVcIZSD13doAScQujyAYtbSD2t1vUeu%2Fg2Go56pz4%2BaGBcOkWNojBV8dhhPWmbbPnjVsaflPy09PfDVA5S1JEn8K11xzYOeE%3D
