Wanted to add this here in case someone is struggling with configuring a similar device for Tuya Local.
I got the device from Amazon and it actually has two LED sources:
- Main: white temperature/brightness
- Outside: color/brightness
Installation is really easy and, as usual, it works directly with Tuya app (beside Smart Life). Once configured you can go to your Local Tuya integration and configure it as below:
It doesn’t seem to allow setting both sources on at the same time, but when color is white you can set the light Temperature and the main source will turn on. For other color the main turns off and outside Led ring will light up.
