Tuya combined Sensor in Home Assistant
Hi, I have a Tuya sensor running, which measures the temperature, ORP-value and the ph-acidity of the pool water. Now I am wondering what kind of sensor I have to use in the LocalTuya integration. Any ideas?
hi, do you have more info? was also interested in a tuya pool sensor, what did you buy ?
Side comment…if you read the posts and discord channels you will find very little appreciation for Tuya (wifi). It is clear that in certain cases one does not have a choice but if you have a choice, the recommendation is to avoid it
my alternative approach was esp32 with BT
But i have a lot of tuya devices, dont have issues with it using localtuya
