I have Tuya Compatible LCD Thermostat + IR Device, however it is not supported by home assistant as far as I can see. Any blueprint for this device ?
What does it do that you need to control?
If it’s Tuya compatible, is it Zigbee, WIFI, Bluetooth?
This device is wifi version not zigbee. It also has IR control. I am using this device to control my boiler and AC unit. However I can’t read any temperature or control IR option with HA.
It doesn’t need a blueprint. It needs an integration.
I would change the topic to hardware.
