Tuya component doesn't work with this DIGOO DG-SP01 PLUG
Hello All
I’m having a issue to try add this device DIGOO DG-SP01, to the Home assistant over the Tuya component.
digoousb
The component is configured and working properly I have several other devices working without any problem over this component.
Recently I received this device DIGOO DG-SP01 and I can’t find this device on the Home assistant, it’s added on the smart life app but doesn’t appear on the Home Assistant side I already try to restart several times the HA and running the services force_update or pull_devices without success for now …I Also access over the smart life app to the device information in order to verify the info about this device I try to Search in the Current entities over the HA for the device ID of this device without success again …
The ideia is to use this without flash other firmwares for now…
Is there any way to add this manual or other way to get this working on the Home assistant?
Any one have this device working on the Home assistant right now ?
Thank you and best regards
