Sorry, if this is not the right spot for this question, but are wanting to try to find out how Tuya-convert OTA would work with a couple of lights on the same switch that are hard wired in? Would it just connect to whatever of the devices responded first? Then simply repeat the process for each other device??
I haven’t wired in the new lights yet, so it’s still an option to wire in the first light, flash, then wire in next, flash, etc.
But, if it can handle multiples would be good because I have a whole bunch of GU10 globes to flash as well which are all on a same switche with at least 3 more globes
