Tuya Converted dimmer - how to configure?
Hi Guys,
This is my Dimmer: https://www.cesmarthome.com/WF500D.html
(it worked ok in before in HA with the stock tuya firmware)
I have successfully “tuya converted” my tuya dimmer.
it’s now running tasmota 6.5.0.
my issue is that I can’t get it to function, at all.
The physical switch still works. I can log in to tasmota via the switch’s local IP.
I thought this dimmer would have been easy since there’s a “Tuya Dimmer” module… but the ON/Toggle does nothing, and the dimmer slider does nothing. (I tried 2 other dimmer modules… and no luck)
On the wiki, I found this to configure a new device from scratch - But I’m having a very hard time following it. I assigned a relay to each GPIO#… but then, where are the “virtual buttons”?? (I can’t see them) I manually typed GPIO1-16 in the cosol… but still, nothing happen.
Travis Griggs from Digiblur was kind enough to help me out on the DrZZ FB page. he pointed me to this:
moving the RX to GPIO13
& TX to GPIO15
fixed my issue :slight_smile:
