Tuya CT Zigbee Energy Meter paired with HA but showing power readings of 0
Hi all,
Have a Tuya Bi-Directional CT meter - 2 channel version. Successfully paired/interviewed with Zigbee2MQTT, but all power/energy readings show 0, though it does should voltage and hz values. Tried reversing CT direction/removing one clamp/swapping clamps. Any suggestions to remedy this ? Screenshots and panel picture below. It’s clamped to a mini-split AC eg 110v per leg. HA on a Raspberry Pi 4 with Sonoff 3.0 USB Zigbee dongle.
Would greatly appreciate any advice !
Des
Have you had any luck? I am able to get readings on mine, i have it hooked into the mains coming in, but in order for me to see up to date readings, i have to “reload” the tuya integration everytime. Unfortunately I only have the wifi version, i think i should get the Zigbee
