Tuya Curtains only tilts in Homekit
Hi all,
I’ve been searching for the answer and I can’t quite figure it out. I have some curtains connected via Tuya to Homekit. I’m able to open, close, and adjust the tilt in the Tuya app. However, I’m only able to tilt it when I use it in the Home app. I believe I should adjust this in the configuration.yml file, but I’m unsure how to do this. I’m hoping someone can help. TIA!
Are you using Home Assistant? This is a community related to the Home Assistant software for smart home control. It sounds like homekit has not fully implemented your particular tuya device. It would be worth trying a simple home assistant install with the tuya integration to see if it works better for you.
