I have a tuya ceiling lamp that is switched by the normal light switch. I want to use HomeAssistant to activate different scenes to create lighting mood. As soon as the lamp is switched off / on again via the light switch, it lights up in white mode.
But after a few times off and on, at irregular intervals, the lamp only flashes and is reset. It then only helps to switch the lamp off and on again several times (power off) until it lights up again “normally”.
Is there any way to deactivate the HardReset on tuya devices?
Thanks for your help!
murphy
