TUYA device have no entity
Hello, as some of you already knows, I’m novice and just start to play for 1 week now with HA. I understood from one of my post that to use the energy board I need a power meter. So I Bought one ( here in Thailand it is very difficult to find). it is a Tuya Power Clamp. I followed all the process to add it ( open account on Tuya IOT site, etc…). then I finally have all my Tuya devices added in HA. Good! But the issue is that about the power clamp it is listed but in Configuration/device/copntrol : this device have no entity… can you please help me? thank you so much :slight_smile:
same situation here. Maybe Tuya doesn’t support HA any longer???
Hi, well it is working, I will send you the different steps I used to get it worked:-) no need to buy a new set of power clamp , this one work fine :slight_smile:
I got it working using LocalTuya. Thx.
Hi I have same issue here. Can you share the step how you get it done.
I have added it with local tuya but only get 1 entity but it like random number. No meaning at all.
I attached my device, is this same as yours?
Thank you in advance.
321-GOOGLE-300x300
Have you got it to work?
