Tuya devices disable discovery
Hey guys. I have 4 holiday houses using Tuya light switches and home automation.
I have an issue where if a guest holds a button down for 10 seconds the device goes into discovery, then I can’t automate it until I drive out to the property and rediscover it.
Does anyone know if you can disable the reset or discovery option of a device. Haven’t been able to find it anywhere on google but then I may be missing the search term. You would think if a device that has been paired and then gets put back into discovery would have a timeout after say 30 mins to go back to previous known settings or something
I thought maybe someone on here may have figured it out, hopefully.
Since this feature is there by design, I don’t think there’s going to be an easy answer short of flashing custom firmware.
