Tuya sees my devices but some of them are misbehaving. 4 of my switches are working but two are not. In my dashboard when I toggle my fan switch on my fan comes on and the switch moves. But after a few seconds the switch on my dashboard flips back as if the device were off. The fan stays on. If I toggle it on nothing happens and in a few seconds the virtual switch on dashboard flips to off. Interestingly, If I toggle it on and then off fast I can turn off the device.
The issue started a few days ago. Tuya stopped working completely in HA. I followed these instructions and seemed to get things working:
All through this the Tuya app works and the Tuya developer page shows my devices. I can see my devices in HA they just dont seem to update properly.
I have tried:
-In Tuya I reset the plugs and set them up as new.
-In HA I got rid of any references to the old plugs
Here is one thing I dont understand how Tuya is now integrated into HA. It used to be an integration and I could just delete it. But with this new setup there is not an integration. The instructions had me create a folder called smart life. I cant figure out how to disable that folder to see if I could reinstall Tuya. I’m hesitating to delete it because then I might lose control over the plugs that are working.
Why is this happening? Tips? Should I blank the smart life folder and try installing local Tuya?
