Since a couple of weeks I added a so called digital led strip from Tuya (WIFI/RGBWW) to my bedroom. Created an automation that the led strip will slowly turn on in the morning as part of a wake-up routine.
Unfortunately the moment the led strip turns on it gives a bright blueish flash. (in and outside the automation and also when turned on in the Tuya app)
As you can understand this is far from what were looking for.
Can you double check the experience through tuya app itself? There are similar features like automations in the app, so we can find if this is an output of home assistant integration or the lamp itself.
