Tuya Dimmer ESPHome
I’ve just gotten myself one of these switches https://banggood.app.link/QhYVQZlrNY
I’m running Tasmota on it right now with the Tuya Dimmer configuration, everything is running fine but I have all my other ones on ESPhome.
Does anybody have a working sketch for a similar dimmer? I have seen the ones from Martin Jerry but they seem to do quite a lot more than this.
Hi I have the US fan switch version and would like to do the same as well. How did you flash Tasmota on the switch ?
I’d did it OTA with Tuya Convert from a Raspberry Pi. A video guide is available here https://youtu.be/O5GYh470m5k :blush: And more of a overview video of Tuya Convert here
https://m.youtube.com/watch?v=q4HrpSORcXA
OK managed to flash Tasmota onto the switch but how did you get it working with home assistant
Easiest way is to enable MQTT Discovery on tasmota and it will pop up in Home Assistant. https://github.com/arendst/Sonoff-Tasmota/wiki/Home-Assistant
But you could also use manual config
Just done my first tuya-convert on a teckin plug but I also have these dimmers installed.
Could you share you ESPHome .yaml if you were successful?
