If you mean re-linking the dimmer. Yes several times. Works well with the tuya app and inside HA. The only small issue is google says “Encountered unknown error” when setting brightness or turning dimmer switch on. Turning off from Google is OK.
This is the dimmer I am using. Works OK, pretty big in the box, needs a neutral. With HASSIO it works properly but when setting the % brightness it works properly but google says “encountered an unknown error”. Any further questions, let me know.
Yes, I have all my lights and plugs configured in tuya app and use the tuya component in HA to control them in automations and the HA GUI or can control it with tuya app directly on my phone or using GoogleHome via the tuya app. This solution provides a lot of flexibility.
The dimmer I used is the one at the top of this post.
Thanks for answering, i have the same dimmer and i’m trying to integrate it to HA, i would like to use the custom component so won’t depends on WEB, if you can help with:
You are using the Tuya HA build in or the custom component?
can you control dimming from home assistant and what configuration you are using for the dimmer?
Thanks in advanced
This give you an entity for all your Tuya items defined in the web service. The dimmer is adjustable inside HA.
The icing on the cake with using the web service is it can also be integrated with google home easily and independently from HA. In the end 3 ways to control your dimmer that all interact with each other properly.
Thanks for your answer, i had it on web , but what i try to have Internet independent and run all locally, i have plugs working fine with the custom component but not the dimmer.
Anyway thanks, i’ll keep testing.
thanks
Hy, im working on the same “problem”.
I have 4 pcs Martin jerry 3way dimmer
Controll them with the cloud component is very slow.
I have succesfully configured it with localtuya component, but it is only shows up as a switch…
You can flash tasmota on it if it has an esp module. It is the best solution.
But if it has something else, like the MJ dimmers, we need to find an other way.
