Hi everyone
I bought a tuya door sensor wifi. My goal is to modify it and connect two wires to it, to simulate the opening/closing of the sensor. Where should I connect them? I thought I’d find a magnetic contact but I don’t see it. I attach photos
Hi everyone
The magnetic reed switch is probably on the other side of the PCB.
I soldered the circuit to get the magnetic switching sensor out. I attached the extension sensor to the keyhole to determine the lock status of the door.
I tried it for 1 week. There’s a problem: the sensor runs out of battery unusually quickly.
Has anyone tried it yet?
So I got one and mapped out the circuit noting that my sensor is different to either of the above, mine also has the ZTU module as it is the zigbee variant, either way this is what I came to after beeping it out (excuse the messy scribble):
U1 - HM6207 is the hall effect sensor, the modern fancy reed switch type component, most likely considerably cheaper and more robust, as this hall effect sensor has extra componentry to make it act like a reed switch (binary) instead of a hall effect sensor (how much attraction is in the air… or for the less whimsical, magnetic strength)
A glance at the resistor selection shows where all the battery draining is coming from, R6 on my board, a little 31ohm resistor.
As I am tired and cant remember all the standard voltage drops over standard comments… and I had my multimeter out… I measured the voltage drop over R6 and R0 when ‘door’ was open and closed
R6 (31R)
Closed: 0V
Open: 2.6V
R0 (2M4)
Closed: 0.1mV
Open: 3.13V
Doing the maths to get the current:
R6 (31R)
Closed: 0V = 0A
Open: 2.6V = 84mA
R0 (2M4)
Closed: 0.1mV = 5/8 of sfa
Open: 3.13V = 1.3uA
Sooooo, this device was designed to sense a door, which in most cases is closed most of the time… so the 84mA expenditure when open is managable… buuut when you remove the magnet and use a reed switch to bring it low (closed), you are inverting that paradigm so it is using more current when your reed switch is open (for a normal reed switch, that would be the magnet not in range).
With the upper limit of AAA capacity at 1200mAh, this would give you 14hrs not factoring in the overheads like the MC and radio
lots of words to say that ‘of course your battery is running low quick’.
Looking back at the circuit, I will be removing the transistor (Q3) and connecting my reed switch between its pin 3 and ground which will give me between (effectively) 0A and 1.3uA.
Rough calculations gives this running for 105 years in its open state (not factoring in overheads of course)
I havent done mine yet… but it is on the list to do today… any minute now…
For anyone with a different board, beep yours out, it will most likely be the same overall circuit as I mapped out in the above pic, just with different labels and locations
To update:
removed the transistor and added the external reed switch.
has been on battery pretty much the last 6hrs while I was faffing about getting everything else setup
preliminary result:
Battery: 100%
I now have a sensor on my water meter!
No pics sorry, was in ‘just get it done before the kiddo gets home’ mode.
If I remember I will give a longer term battery update… maybe in a decade or two…
I have an older version, the PCB is similar and marked 2255. The board was designed with the hall sensor on the wrong edge and it had been bodged into the correct spot !! On this one R6 is 1K2.
With this mod I get 1.9uA when closed (D7 high) and 3.3uA when open (D7 pulled to Gnd) and using the max hold function on my meter I see 1mA every now and them which I assume is the transmit current.
Other things I found are that the pairing switch goes to D3 and B4 goes to Q2 to turn on the LED. Q1 is something to do with power switching as it controls the negative rail but now idea how that works.
I’ll be using it on the door of a storage container with a chunky spring loaded switch so I hope the de-bounce has been taken care of in the firmware.
Yeah, I bought 2 different ones at the same time as I saw the issues people were having with it.
The circuit on the one above suggests that they have no idea how that hall effect sensor works, it has a pull push output so doesnt need any of the extra circuitry, just adding a huge drain.
The other one I have has the hall effect plumbed directly to the controller pin, but also has an alternate path to an external sensor with the above circuit path just unpopulated, so it is possible that the transistor part was from the original reed switch design that they never undid.
If I get the chance, I may see if these things can be reprogrammed (without too much faffing about) to use some of the other pins as secondary sensors.
regarding the debounce, it seems to be solid in firmware, I have mine being used as a water meter (spinning magnet disk thing), which is sporadic, stop start and is quite likely to stop at the threshold of the reed switch. When I checked last, the reading was spot on.
I will admit, there are lots of functions on my multimeter that I dont (know how to) use, when I was learning all this stuff I had an o’scope at hand… and as it was ‘learning what you need to do the next thing’ there are plenty of holes… maybe when I retire (entirely too long away) I can finally learn something properly ![]()
So what you say is that the original door/window sensor would be empty if you open the window or door for more than 1 day? (So without adjusting the original product)
I recently bought this sensor which is very easy to expand. type: ZY-ZD02-ZTU_V1.2
I wanted to buy a few more of this, but these no longer came in the sale.
Where you have the HM6207, there is 20631 on my board?
The one I have ordered now (item: https://nl.aliexpress.com/item/1005006285992341.html ) would be the same as yours, given the curves (your corners are somewhat rounder) ? It’s still on transit.
Power Consumption Test for Zigbee Door Sensor (MC510A-A002)
I received the Zigbee door sensor (MC510A-A002, link) and performed a current consumption test. Here’s the setup I used:
Assuming a 1,000 mAh AAA battery (since the current remains the same in series), the battery life can be roughly calculated as:
With the contact closed:
1000 mAh / 6.9 µA = 144,927 hours = 6,038 days = 16.5 years
After this time, the battery will likely drain due to self-discharge.
With the contact open:
1000 mAh / 3.7 µA = 270,270 hours = 11,261 days = 30 years
Again, the battery will eventually drain on its own over time.
This calculation doesn’t take into account the keep-alive status messages, which consume between 1 and 2 mA, with occasional peaks up to 2.56 mA. These higher current draws will lower the overall battery life.
I haven’t connected an external contact yet, but based on this measurement, it seems there’s no issue with the current consumption of the sensor, right?
Take a look here:
There is plenty of information, even for the new ones that have a hall sensor instead of a reed sensor.
Looks like that board is a full redesign with an integrated mcu and antenna instead of the zigbee module.
From your measurements, they may have actually put some thought into redesigning it instead of just throwing components at it and hoping for the best.
Mind you, given the variance out there in the ‘same’ devices… You may just be very lucky
nice pickup.
Looks like the hall effect sensor is on the other side of the purple board. Find it, take a look at its datasheet and work out where it is best to tap into the circuit for your reed switch
As a quick update on the battery now that I am back here, it is sitting at 84% after 5 months.
Given this sensor is used to measure water usage and gets ‘opened’ or ‘closed’ every ~2.5L, It is sending updates much more regularly than a normal door sensor, so I call it a win.
On this board the hall sensor is most likely the U3 on the middle right side, basically near the notch in the outer case.
if you desolder the hall sensor (because if not you will short stuff out but maybe its fine for you)
The pinout is
and when you do
GND → OUT (disconnect VDD from OUT) then its closed I think
VDD → OUT (disconnect GND from OUT) then its open I think
there should be basically same power consumption as stock
but yeah you need to handle this logic somehow or just keep it as is without desoldering and short out GND → OUT but it seems to consume a lot of power so…
there are relays which have NO NC states which completely makes sense with this logic, you put OUT as the input to relay, and NO would be GND and NC would be VDD and that should work fine
