My Tuya based energy meter does not show kWh readings in HA, while it shows that value in the Tuya app.
Any ideas on how to get that value in HA, and add it to the energy dashboard ?
In HA I get this
And this is what I get when I click on "download diagnostics¨
"home_assistant": {
"installation_type": "Home Assistant OS",
"version": "2023.12.3",
"dev": false,
"hassio": true,
"virtualenv": false,
"python_version": "3.11.6",
"docker": true,
"arch": "armv7l",
"timezone": "Europe/Brussels",
"os_name": "Linux",
"os_version": "6.1.63-haos",
"supervisor": "2023.11.6",
"host_os": "Home Assistant OS 11.2",
"docker_version": "24.0.7",
"chassis": "embedded",
"run_as_root": true
"custom_components": {
"jq300": {
"version": "0.10.6",
"requirements": [
"paho-mqtt==1.6.1"
"thermal_comfort": {
"version": "2.2.0",
"requirements": []
"sunnybeam": {
"version": "0.1.1",
"requirements": [
"sunnybeamtool>=0.1.0"
"sonoff": {
"version": "3.5.2",
"requirements": [
"pycryptodome>=3.6.6"
"hacs": {
"version": "1.33.0",
"requirements": [
"aiogithubapi>=22.10.1"
"smart_thermostat": {
"version": "2021.11.1",
"requirements": []
"integration_manifest": {
"domain": "tuya",
"name": "Tuya",
"codeowners": [
"@Tuya",
"@zlinoliver",
"@frenck"
"config_flow": true,
"dependencies": [
"ffmpeg"
"dhcp": [
"macaddress": "105A17*"
"macaddress": "10D561*"
"macaddress": "1869D8*"
"macaddress": "381F8D*"
"macaddress": "508A06*"
"macaddress": "68572D*"
"macaddress": "708976*"
"macaddress": "7CF666*"
"macaddress": "84E342*"
"macaddress": "D4A651*"
"macaddress": "D81F12*"
"documentation": "https://www.home-assistant.io/integrations/tuya",
"integration_type": "hub",
"iot_class": "cloud_push",
"loggers": [
"tuya_iot"
"requirements": [
"tuya-iot-py-sdk==0.6.6"
"is_built_in": true
"data": {
"endpoint": "https://openapi.tuyaeu.com",
"auth_type": 0,
"country_code": "32",
"app_type": "smartlife",
"mqtt_connected": true,
"disabled_by": null,
"disabled_polling": false,
"name": "meter-airco",
"model": "DDS238-2 WIFI",
"category": "cz",
"product_id": "sw9asyjj8j44frjl",
"product_name": "meter",
"online": true,
"sub": false,
"time_zone": "+01:00",
"active_time": "2022-04-27T16:51:07+00:00",
"create_time": "2020-10-10T15:43:47+00:00",
"update_time": "2023-12-17T23:06:39+00:00",
"function": {
"switch_1": {
"type": "Boolean",
"value": {}
"countdown_1": {
"type": "Integer",
"value": {
"unit": "s",
"min": 0,
"max": 86400,
"scale": 0,
"step": 1
"status_range": {
"switch_1": {
"type": "Boolean",
"value": {}
"countdown_1": {
"type": "Integer",
"value": {
"unit": "s",
"min": 0,
"max": 86400,
"scale": 0,
"step": 1
"cur_current": {
"type": "Integer",
"value": {
"unit": "mA",
"min": 0,
"max": 100000,
"scale": 0,
"step": 1
"cur_power": {
"type": "Integer",
"value": {
"unit": "W",
"min": 0,
"max": 500000,
"scale": 1,
"step": 1
"cur_voltage": {
"type": "Integer",
"value": {
"unit": "V",
"min": 0,
"max": 5000,
"scale": 1,
"step": 1
"status": {
"switch_1": true,
"countdown_1": 0,
"cur_current": 167,
"cur_power": 123,
"cur_voltage": 2388
"home_assistant": {
"name_by_user": null,
"disabled": false,
"entities": [
"disabled": false,
"entity_category": null,
"device_class": null,
"original_device_class": "current",
"icon": null,
"original_icon": null,
"unit_of_measurement": "A",
"state": {
"entity_id": "sensor.meter_airco_current",
"state": "0.167",
"attributes": {
"state_class": "measurement",
"device_class": "current",
"friendly_name": "meter-airco Current"
"last_changed": "2023-12-18T19:22:52.070795+00:00",
"last_updated": "2023-12-18T19:22:52.070795+00:00"
"disabled": false,
"original_device_class": "power",
"icon": null,
"unit_of_measurement": "W",
"state": {
"entity_id": "sensor.meter_airco_power",
"state": "12.3",
"attributes": {
"device_class": "power",
"friendly_name": "meter-airco Power"
"last_changed": "2023-12-18T19:23:51.908323+00:00",
"last_updated": "2023-12-18T19:23:51.908323+00:00"
"disabled": false,
"original_device_class": "voltage",
"icon": null,
"unit_of_measurement": "V",
"state": {
"entity_id": "sensor.meter_airco_voltage",
"state": "238.8",
"attributes": {
"device_class": "voltage",
"friendly_name": "meter-airco Voltage"
"last_changed": "2023-12-18T19:41:48.818025+00:00",
"last_updated": "2023-12-18T19:41:48.818025+00:00"
"disabled": false,
"original_device_class": "outlet",
"icon": null,
"unit_of_measurement": null,
"state": {
"entity_id": "switch.meter_airco_socket_1",
"state": "on",
"attributes": {
"device_class": "outlet",
"friendly_name": "meter-airco Socket 1"
"last_changed": "2023-12-18T00:13:50.828782+00:00",
"last_updated": "2023-12-18T00:13:50.828782+00:00"
