Advice on a zigbee device please : Tuya flash and siren device TS0216 exposes one sensor ‘Ias_zone’ when connected via ZHA in HA. When using Zigbee2MQTT, it has two configurable states - siren level (0-100) and siren on/off. I cant use Z2MQTT anymore (long story - but essentially ZHA is much more stable and faster) - so I need this device to be usable via ZA.
Im assuming this device needs a custom_quirk - (I see its in the zigbee-herdsman library as used by zigbee2Mqtt already)…Can this device be reconfigured to expose the siren volume, and siren on/off ?
"node_descriptor": "NodeDescriptor(logical_type=<LogicalType.Router: 1>, complex_descriptor_available=0, user_descriptor_available=0, reserved=0, aps_flags=0, frequency_band=<FrequencyBand.Freq2400MHz: 8>, mac_capability_flags=<MACCapabilityFlags.AllocateAddress|RxOnWhenIdle|MainsPowered|FullFunctionDevice: 142>, manufacturer_code=4098, maximum_buffer_size=82, maximum_incoming_transfer_size=512, server_mask=11264, maximum_outgoing_transfer_size=512, descriptor_capability_field=<DescriptorCapability.NONE: 0>, *allocate_address=True, *is_alternate_pan_coordinator=False, *is_coordinator=False, *is_end_device=False, *is_full_function_device=True, *is_mains_powered=True, *is_receiver_on_when_idle=True, *is_router=True, *is_security_capable=False)",
"endpoints": {
"1": {
"profile_id": 260,
"device_type": "0x0403",
"in_clusters": [
"0x0000",
"0x000a",
"0x0500",
"0x0502",
"0xef01"
"out_clusters": [
"0x0019"
"manufacturer": "_TYZB01_a5tf0bpl",
"model": "TS0216",
"class": "zigpy.device.Device"
