spanzetta
(Stefano Panzetta)
October 4, 2025, 7:22am
1
After latest Core update I saw a warning regarding Tuya has deprecated switch (I think it refers to 3 Irrigation timer I have) and they will not work after 2026.4…
Unfortunatelly I didn’t save that warning message… so after had closed it I cannot read it anymore (even after a reboot it doesn’t appear)
Can someone pls explain what should I do?
Thanks in advance
spanzetta
(Stefano Panzetta)
October 5, 2025, 3:19pm
2
Found the source
dev ← epenet-20250917-1109
opened 09:20AM - 17 Sep 25 UTC
## Proposed change
SSIA
## Type of change
- [ ] Dependency upgrade
- [ ] Bug… fix (non-breaking change which fixes an issue)
- [ ] New integration (thank you!)
- [ ] New feature (which adds functionality to an existing integration)
- [x] Deprecation (breaking change to happen in the future)
- [ ] Breaking change (fix/feature causing existing functionality to break)
- [ ] Code quality improvements to existing code or addition of tests
## Additional information
- This PR fixes or closes issue: fixes #
- This PR is related to issue:
- Link to documentation pull request:
- Link to developer documentation pull request:
- Link to frontend pull request:
## Checklist
- [ ] I understand the code I am submitting and can explain how it works.
- [ ] The code change is tested and works locally.
- [ ] Local tests pass. **Your PR cannot be merged unless tests pass**
- [ ] There is no commented out code in this PR.
- [ ] I have followed the [development checklist][dev-checklist]
- [ ] I have followed the [perfect PR recommendations][perfect-pr]
- [ ] The code has been formatted using Ruff (`ruff format homeassistant tests`)
- [ ] Tests have been added to verify that the new code works.
- [ ] Any generated code has been carefully reviewed for correctness and compliance with project standards.
If user exposed functionality or configuration variables are added/changed:
- [ ] Documentation added/updated for [www.home-assistant.io][docs-repository]
If the code communicates with devices, web services, or third-party tools:
- [ ] The [manifest file][manifest-docs] has all fields filled out correctly.
Updated and included derived files by running: `python3 -m script.hassfest`.
- [ ] New or updated dependencies have been added to `requirements_all.txt`.
Updated by running `python3 -m script.gen_requirements_all`.
- [ ] For the updated dependencies - a link to the changelog, or at minimum a diff between library versions is added to the PR description.
To help with the load of incoming pull requests:
- [ ] I have reviewed two other [open pull requests][prs] in this repository.
[prs]: https://github.com/home-assistant/core/pulls?q=is%3Aopen+is%3Apr+-author%3A%40me+-draft%3Atrue+-label%3Awaiting-for-upstream+sort%3Acreated-desc+review%3Anone+-status%3Afailure
[dev-checklist]: https://developers.home-assistant.io/docs/development_checklist/
[manifest-docs]: https://developers.home-assistant.io/docs/creating_integration_manifest/
[quality-scale]: https://developers.home-assistant.io/docs/integration_quality_scale_index/
[docs-repository]: https://github.com/home-assistant/home-assistant.io
[perfect-pr]: https://developers.home-assistant.io/docs/review-process/#creating-the-perfect-pr
The message says:
"The Tuya entity {entity} is deprecated, replaced by a new valve entity.\nPlease update your dashboards, automations and scripts, disable {entity} and reload the integration/restart Home Assistant to fix this issue.
and
breaks_in_ha_version=“2026.4.0”
Should I simply disable those entity? Or delete them?
What will happen then?
francisp
(Francis)
October 5, 2025, 3:24pm
3
As the message says: the switch is now a valve. First change your automations and dashboard to use the valve, then delete the switch.
spanzetta
(Stefano Panzetta)
October 5, 2025, 4:27pm
4
Thanks for the clarification…
I realized that both valve and switch are already available … that’s why I was confused about what to do…
Now I got the point…
Thanks again
spanzetta
(Stefano Panzetta)
October 5, 2025, 4:36pm
5
I now have have a problem…
Now that Tuya water timer switch are replaced by valve entities… how to use them with Scheduler? I see that only switch can be used… valve doesn’t appear in the list (even if added as “included entities”…
How to solve?
spanzetta
(Stefano Panzetta)
October 7, 2025, 9:54am
6
I found the way to use valve (need to restart creating my schedule)…
Solved!
