Tuya - How to map data points? - Pet feeder
Hi all,
Yesterday I got a LSC Smart pet feeder and added it in Home Assistant with the integration Tuya
I noticed that the app has a lot more features than home assistant is viewing:
I saw online on how to get data points in Tuya development and pulled them for the pet feeder and ended up with:
{“103”:“Flip”,“106”:“Motion detector sensitivity”,“108”:“Night Vision”,“111”:“存储卡格式化”,“115”:“Motion Detection”,“117”:“格式化状态”,“134”:“Motion”,“150”:“SD卡录像开关”,“151”:“录像模式”,“231”:“Feed”,“232”:“Food Weight”,“233”:“Realtime Data”,“234”:“History Data”,“235”:“短音录制”}
I also pulled a more readable export from the api explorer with all DP’s:
  "result": {
    "category": "sp",
    "functions": [
        "code": "basic_flip",
        "desc": "{}",
        "name": "反面翻转",
        "type": "Boolean",
        "values": "{}"
        "code": "motion_sensitivity",
        "desc": "{\"range\":[\"0\",\"1\",\"2\"]}",
        "name": "移动侦测灵敏度",
        "type": "Enum",
        "values": "{\"range\":[\"0\",\"1\",\"2\"]}"
        "code": "basic_nightvision",
        "name": "红外夜视",
        "type": "Enum",
        "code": "sd_format",
        "desc": "{}",
        "name": "存储卡格式化",
        "type": "Boolean",
        "values": "{}"
        "code": "motion_switch",
        "desc": "{}",
        "name": "移动报警开关",
        "type": "Boolean",
        "values": "{}"
        "code": "record_switch",
        "desc": "{}",
        "name": "SD卡录像开关",
        "type": "Boolean",
        "values": "{}"
        "code": "record_mode",
        "desc": "{\"range\":[\"1\",\"2\"]}",
        "name": "录像模式",
        "type": "Enum",
        "values": "{\"range\":[\"1\",\"2\"]}"
    "status": [
        "name": "反面翻转",
        "type": "Boolean",
        "values": "{}"
        "name": "移动侦测灵敏度",
        "type": "Enum",
        "name": "红外夜视",
        "type": "Enum",
        "code": "sd_storge",
        "name": "获取存储卡容量",
        "type": "String",
        "values": "{\"maxlen\":255}"
        "code": "sd_status",
        "name": "存储卡状态",
        "type": "Integer",
        "values": "{\"min\":1,\"max\":5,\"scale\":0,\"step\":1}"
        "name": "存储卡格式化",
        "type": "Boolean",
        "values": "{}"
        "code": "movement_detect_pic",
        "name": "移动检测",
        "type": "Raw",
        "values": "{}"
        "code": "sd_format_state",
        "name": "格式化状态",
        "type": "Integer",
        "values": "{\"unit\":\"\",\"min\":-20000,\"max\":200000,\"scale\":0,\"step\":1}"
        "name": "移动报警开关",
        "type": "Boolean",
        "values": "{}"
        "name": "SD卡录像开关",
        "type": "Boolean",
        "values": "{}"
        "name": "录像模式",
        "type": "Enum",
  "success": true,
  "t": 1723719954134,
  "tid": "570f826e5af611ef883136d89ae34f8e"
But my question is, how do I correctly map these data points so I can use them in HA? If there is a guide or something, that would be great. I tried using local tuya but that doesn’t seem to work. I heard people talking about tuyalocal being better but i can’t seem to find that integration…
Prefferably I would add these dp’s in the tuya cloud integration since that seems to work the best, but I have no idea how.
Also if there are more people with this pet feeder, let me know what you figured out. :slight_smile:
Thanks!
I got a little further, I now got the DP ids from Iot Tuya
  "result": {
    "properties": [
        "custom_name": "",
        "dp_id": 103,
        "time": 1723910842385,
        "type": "bool",
        "value": false
        "custom_name": "",
        "dp_id": 106,
        "time": 1723813952722,
        "type": "enum",
        "value": "0"
        "custom_name": "",
        "dp_id": 108,
        "time": 1723813952760,
        "type": "enum",
        "value": "0"
        "custom_name": "",
        "dp_id": 109,
        "time": 1723813953033,
        "type": "string",
        "value": "896|896|0"
        "custom_name": "",
        "dp_id": 110,
        "time": 1723813953079,
        "type": "value",
        "value": 5
        "custom_name": "",
        "dp_id": 111,
        "time": 1723650126400,
        "type": "bool",
        "value": false
        "custom_name": "",
        "dp_id": 115,
        "type": "raw"
        "custom_name": "",
        "dp_id": 117,
        "time": 1723650130139,
        "type": "value",
        "value": 0
        "custom_name": "",
        "dp_id": 134,
        "time": 1723650129819,
        "type": "bool",
        "value": false
        "custom_name": "",
        "dp_id": 150,
        "time": 1723650130038,
        "type": "bool",
        "value": true
        "custom_name": "",
        "dp_id": 151,
        "time": 1723803105627,
        "type": "enum",
        "value": "1"
        "code": "feed_num",
        "custom_name": "",
        "dp_id": 231,
        "time": 1723878182225,
        "type": "value",
        "value": 4
        "code": "food_weight",
        "custom_name": "",
        "dp_id": 232,
        "time": 1723650173063,
        "type": "value",
        "value": 10
        "code": "realtime_data",
        "custom_name": "",
        "dp_id": 233,
        "time": 1723878177015,
        "type": "enum",
        "value": "0"
        "code": "history_data",
        "custom_name": "",
        "dp_id": 234,
        "type": "bool",
        "value": false
        "code": "feed_voice_record",
        "custom_name": "",
        "dp_id": 235,
        "type": "enum",
        "value": "0"
        "code": "schedule",
        "custom_name": "",
        "dp_id": 236,
        "time": 1723877353330,
        "type": "string",
        "value": "7f0820041000000"
  "success": true,
  "t": 1723910852986,
  "tid": "cf9e5aaf5cb211ef883136d89ae34f8e"
And I know which yaml is being used in TuyaLocal for this device, it’s “ceres_plus_petfeeder.yaml” so now I need to know how I can include some of these DP ids so I can enrich the entities in HA.
Anyone who can help me out?
I’m in a similar boat. I bought a Kogan 4L pet feeder with camera and it seems to have the same DP Ids as yours. I have been trying to get it integrated into HA but without much luck.
I’ve also been trying with LocalTuya to manually send the command via DPId 231.
When going through the command setup, 231 is weirdly omitted from the list of available ones, so I tried adding it using the Manual DPS to add and setting it as a number (ranging from 0-10). When created, the entity has a value on “unavailable”, and manually setting the state via HA DevTools changes the value to 1, but it doesn’t seem to send the command to the device.
If I login to iot.tuya.com and navigate to “Debug Device”, set feed_num to 1, and hit “Send Instruction”, then it does trigger a feed. To note, when I do it via the IOT website (or via the SmartLife app) it makes the entity in HA revert back to “unavailable”.
I don’t know where to go from here. I’m not so much fussed about getting the camera entities working (though that would be nice), I would just like to be able to send a “feed” command via HA and not have to go via the SmartLife app.
If anyone has any suggestions on how to try this, please let me know
Screenshot of the IoT area where I can Send the feed_num Instruction
I have also an LSC smart pet feeder and trying to integrate it in HA. But i’m kinda get lost i the ocal tuya, tuya local, tuya and setting up dps. So hopefully someone did managed to get it working and is willing to give some usefull tips.
Using Tuya cloud or Tuya local it’s fairly simple to integrate the device in HA. Just add it to your tuya app or smart life app on your phone, after that click add device in the preffered tuya integration.
At that point the device should be visible, if you followed the steps of setting up the tuya integration itself of course.
But you will be missing functions like me and unfortunately, I still haven’t figured out how to add the extra DPS’s…
The only thing I get is a camera feed. But I don’t be nice if I can set the schedule for example.
Today I’ve bought some pet feeder. Also only got basic settings and camera view by default.
But pro tip; Create some “tap to run” scene in the Tuya app.
Be careful; Settings for dispenser are horrible. First tries it just kept depending 100+ portions :joy:.
But after finetuning it, I can dispend 2 portions on 1 click.
After reloading Tuya integration in HA, I got my scene and I can click in home assistant to dispend some food to my catties.
Only schedule is still in the app.
I keep it that way, hoping the machine will know the schedule and if it runs on schedule on backup power because of some power issue (and then also no network?).
I finally added my dp103 flip camera (as if anyone would ever need that….) none sensical pet feeder to local tuya…I used the fork of the most popular one GitHub - xZetsubou/hass-localtuya: 🔹 A Home Assistant integration to handle Tuya devices locally "fork from localtuya" this
I just kept hitting add like there is no tomorrow, because it kept saying try again like hundreds of times……and bingo possibly at the 1000th click it added. Then I configured the feed dp 231 and I am done with it…
During the process I tried other none sensical dps to add but guess what happened while feeder reset itself and returned to factory mode…no idea why. Add again to smart life was painful and get local keys etc… but I didn’t give up. It is so weird connection seems super good with tuya cloud but local it sucks…unlike other tens of tuya devices I have.
