I’ve bought me a Zigbee Tuya Human presence sensor and configured it successfully with Zigbee2MQTT.
But the Illuminance sensor is missing in HomeAssistant, in the Zigbee2MQTT dashboard I can see the the Illuminance value.
Is it possible to add this somehow ?
Zigbee-Modell TS0225
Zigbee-Hersteller _TZE200_2aaelwxk
Beschreibung 5.8Ghz Human presence sensor
Did you check the sensors list in the device view of the corresponding device? Maybe the sensor is hidden or disabled. From the device page you can see all sensors/entities and enable them if you want.
If that doesn’t work for you, you can also try to add the sensor manually in the mqtt integration. MQTT Sensor - Home Assistant
AFAIK this has nothing to do with configuration.yaml. I’m not sure why in your case the lux sensor got disabled by default (usually this happens with diagnostic data from Zigbee, so this is what I’m showing below, but the workflow is the same):
click that disabled entity you circled
press the top-right button
enable it, then confirm (in English the button is called “update”)
