Tuya - I think something has gone wrong
Hi everyone
I’m pretty new to Home Assistant, and while I’ve done well setting some things up, other things have been a little harder for me to get my head around. I had a nervous breakdown a couple years ago so I struggle with this stuff sometimes.
I looked at the log a moment ago, and it looks like my Tuya integration isn’t running as it should. Here is the log -
Logger: homeassistant.components.select
Source: components/tuya/base.py:101
Integration: Select (documentation, issues)
First occurred: 2:54:26 AM (1 occurrences)
Last logged: 2:54:26 AM
Error while setting up tuya platform for select
File “/usr/src/homeassistant/homeassistant/helpers/entity_platform.py”, line 249, in _async_setup_platform
await asyncio.shield(task)
File “/usr/src/homeassistant/homeassistant/components/tuya/select.py”, line 294, in async_setup_entry
async_discover_device([*hass_data.device_manager.device_map])
File “/usr/src/homeassistant/homeassistant/components/tuya/select.py”, line 287, in async_discover_device
TuyaSelectEntity(
File “/usr/src/homeassistant/homeassistant/components/tuya/select.py”, line 316, in init
if enum_type := self.find_dpcode(
File “/usr/src/homeassistant/homeassistant/components/tuya/base.py”, line 230, in find_dpcode
enum_type := EnumTypeData.from_json(
File “/usr/src/homeassistant/homeassistant/components/tuya/base.py”, line 101, in from_json
if not (parsed := json.loads(data)):
File “/usr/local/lib/python3.9/json/init.py”, line 346, in loads
return _default_decoder.decode(s)
File “/usr/local/lib/python3.9/json/decoder.py”, line 337, in decode
obj, end = self.raw_decode(s, idx=_w(s, 0).end())
File “/usr/local/lib/python3.9/json/decoder.py”, line 353, in raw_decode
obj, end = self.scan_once(s, idx)
json.decoder.JSONDecodeError: Unterminated string starting at: line 1 column 43 (char 42)
I have the Home Assistant OS running in a VirtualBox on my Windows 10 machine. I really want to learn this stuff, so if there are issues above, I would really appreciate it if it could be pointed out and shared why it’s an issue and how to fix it. If it isn’t really an issue, then that’s great!
I have searched but I didn’t find anything helpful. I apologise for my inexperience, but I am keen to learn. Thank you
Is there a config from configuration.yaml to paste along with this?
This is most likely the issue (a formatting issue)
Thank you for your reply, but it’s not that, because an addition to the configuration file isn’t required.
