I don’t know what’s going on with the New Tuya integration, i can’t seem to get access to Tuya and all my devices are stating they need repair.
Part of the update released today!
Did you read the release notes on Tuya?
Read Breaking changes also
Now that the official 2024.2 has come out, can I remove the Beta channel and the new Tuya Integration will keep working ?
Should be able
Yes, just leave the beta chanel
Hi, I apologise if it appears I’m jumping in.
I’ve a Tuya v2 install with 30+ items. I was prompted to configure the “new” Tuya install. Will this run side by side with the existing V2 or will it just take over the V2 install? Am I correct in assuming I’ll will have to rebuild my dashboards either way to use the new Tuya?
Okay, to reply to my own question.
I went ahead and configured the"new" Tuya.
It’s completely separate to Tuya V2 and will require full re-integration. It is a completely separate integration.
On the bright side it has a few more devices available than V2, cameras & doorbells.
So I’ll just gradually switch over day by day I think.
If this appears as an answer to a dumbass question then I apologise
