walaj
(Jon Waland)
1
Is anyone else finding the off the shelf Tuya integration isn’t working? Separate fro the issue in 106 of slowness.
Turning on a switch via HA doesn’t work, and manually changing the switch isn’t reflected in the GUI. There are no errors in the log files…
nickrout
(Nick Rout)
2
Have you turned logging up?
walaj
(Jon Waland)
3
ok - never dug into debug.
setup as
logger:
default: error
logs:
homeassistant.components.tuya: debug
and I now get limited logging for tuya:
Mar 15 12:51:07 JonLabNUC hass[22410]: 2020-03-15 12:51:07 DEBUG (SyncWorker_9) [homeassistant.components.tuya] Pull devices from Tuya.
What did I do wrong?
(and it is back to slow rather than not working)
walaj
(Jon Waland)
4
ok - no idea. seems working. nothing changed other than restarting hass.
