Tuya Integration HA 2024.02 - QR-code
I am using SmartLife app and I am trying to integrate it to HA 2024.8.2 and I tried to bind my SmartLife account via Tuya. I entered my user code and got a QR. When I scan it with my phone, I am getting an error that I am using the wrong app. When I scanned the QR with my phone (and not the app), I saw that it trying to open tuya app and not smart life app.
Next, I installed the Tuya app (just for testing the QR) and I had not problems to bind HA to it.
How can I modify which app the generated QR code is pointing me?
I found a even easier and faster workaround, if you’re on PC and Chrome.
No need to change any setting or use Firefox!
Simply right click the QR code, save it as an image and open the dowloaded .png file. Scan the QR code from the file you downloaded, confirm the code inside the Tuya/SmartLife app and then return to HA and click on “Submit”. Voilà
Solution offered in this topic didn’t work - change theme default, cache refresh, change browser, nothing.
The ONLY thing that worked was rebooting hass, and then within 180 seconds scanning the code.
I think the integration should be fixed to load a new QR after 180 seconds.
Same here only solution is:
Restart HA and be quick enough to scan the code with the SmarLife App as soon as HA is up again.
Just reloading the account within the Tuya integration seems to not trigger a new QR code generation.
I have kinda similar situation QR code keeps expiring and I see this " Please select the data center that matches the account in the upper right corner of the page, otherwise you will not be able to authorize. If you don’t know the data centre of your account, please check [App account data center distribution]". I am trying to connect Globe Suite smart wifi plugs . I have tried all data centres but no luck. Funny thing I do have Smart life wifi power bar that got connected through same process . Am I doing something wrong?
Brazil: Deu certo!
Ok
I have a Prowarm thermostat and was trying to do this with the Prowarm app.
Didn’t work, had to add device to Tuya app and follow the instructions from there.
GUI on both look nearly identical, but usernames/passwords are completely different, needed to re register on Tuya.
Seems to work now.
Thank you, this solved it for me. :+1:
This worked for me. Firefox.
Can someone please try this? It seemed to work for me but not sure if it was this that fixed it.
  1. Get to the reconfigure screen in tuya home assistant.
  2. Click submit on the reconfigure screen WITHOUT scanning the code with your phone. (the one with the QR)
  3. You should get a failure message
  4. Then on your phone, scan the new QR code.
  5. It should work.
  6. Then click submit in the reconfigure screen.
  7. It should now pass.
the suggestion of jcianci12 worked for me. Thanks!
I just clicked OK on the button of the “too old and expired” QR Code screen on the PC, then you have to wait a moment, a new Code appears, scan it with the Tuya App on your phone, then click “Ok” on the PC again. Maybe you have to try for several times. That worked for me!
 and just in case anyone else has trouble finding how to scan in the Tuya app (it is not something I do regularly)
on the home screen Select ‘+’ and a mini-menu pops up with ‘Scan’ as the last option
(E0020003): Login failed, please scan and try again!
whatever I do from the advice
