Tuya Integration - Improve Air Purifier Integration
I have got a purifier that is quite popular in Poland - Klarta Forste 4. It integrates with Tuya but using the official Tuya cloud component not all functions are present or work correctly. I think I could try to add this functionality as I find out that it is configured at \components\tuya\fan.py. “kj” is for air purifiers. I see that it is recognized correctly and TuyaFanEntity() does the job. I’m new to HA so what is the preffered way to introduce changes?
What I want to improve:
  • at this moment it is impossible to change the fan speed manualy. There is a mode called “Manual” but nothing can be changed.
  • from TUYA/Smart Life app settings that are available: Silent, Silent+, Slow,Slow+,Fast, Fast+, Turbo, Turbo +.
How to start? Who should be asked?
Download the diagnostics and compare it to what you see in fan.py. Post the fan speed section.
Hello. Thanks for the reply.
Please find the data attached. I think that the py code does what is coded.
  "home_assistant": {
    "installation_type": "Home Assistant OS",
    "version": "2025.2.1",
    "dev": false,
    "hassio": true,
    "virtualenv": false,
    "python_version": "3.13.1",
    "docker": true,
    "arch": "x86_64",
    "timezone": "Europe/Warsaw",
    "os_name": "Linux",
    "os_version": "6.6.73-haos",
    "supervisor": "2025.02.0",
    "host_os": "Home Assistant OS 14.2",
    "docker_version": "27.2.0",
    "chassis": "vm",
    "run_as_root": true
  "custom_components": {},
  "integration_manifest": {
    "domain": "tuya",
    "name": "Tuya",
    "codeowners": [
      "Tuya",
      "zlinoliver"
    "config_flow": true,
    "dependencies": [
      "ffmpeg"
    "dhcp": [
        "macaddress": "105A17*"
        "macaddress": "10D561*"
        "macaddress": "1869D8*"
        "macaddress": "381F8D*"
        "macaddress": "508A06*"
        "macaddress": "68572D*"
        "macaddress": "708976*"
        "macaddress": "7CF666*"
        "macaddress": "84E342*"
        "macaddress": "D4A651*"
        "macaddress": "D81F12*"
    "documentation": "https://www.home-assistant.io/integrations/tuya",
    "integration_type": "hub",
    "iot_class": "cloud_push",
    "loggers": [
      "tuya_iot"
    "requirements": [
      "tuya-device-sharing-sdk==0.2.1"
    "is_built_in": true,
    "overwrites_built_in": false
  "setup_times": {
    "null": {
      "setup": 3.8494000001776385e-05
    "01JFVNYDW9MEEVXJAHEY053W2B": {
      "wait_import_platforms": -0.09296991799999432,
      "wait_base_component": -0.0018807639999920411,
      "config_entry_setup": 1.2321792160000058
  "data": {
    "endpoint": "https://apigw.tuyaeu.com",
    "terminal_id": "1735022032570ownMGU",
    "mqtt_connected": true,
    "disabled_by": null,
    "disabled_polling": false,
    "id": "6323176830839884dc5f",
    "name": "Klarta Forste 4 B",
    "category": "kj",
    "product_id": "zxpmhropoeoigxav",
    "product_name": "Klarta Forste 4",
    "online": true,
    "sub": false,
    "time_zone": "+01:00",
    "active_time": "2022-12-19T17:50:23+00:00",
    "create_time": "2022-12-19T17:50:23+00:00",
    "update_time": "2022-12-19T17:50:23+00:00",
    "function": {
      "switch": {
        "type": "Boolean",
        "value": {}
      "mode": {
        "type": "Enum",
        "value": {
          "range": [
            "auto",
            "manual",
            "sleep"
      "anion": {
        "type": "Boolean",
        "value": {}
      "lock": {
        "type": "Boolean",
        "value": {}
      "filter_reset": {
        "type": "Boolean",
        "value": {}
    "status_range": {
      "switch": {
        "type": "Boolean",
        "value": {}
      "pm25": {
        "type": "Integer",
        "value": {
          "min": 0,
          "max": 999,
          "scale": 0,
          "step": 1
      "mode": {
        "type": "Enum",
        "value": {
          "range": [
            "auto",
            "manual",
            "sleep"
      "filter": {
        "type": "Integer",
        "value": {
          "unit": "%",
          "min": 0,
          "max": 100,
          "scale": 0,
          "step": 1
      "anion": {
        "type": "Boolean",
        "value": {}
      "lock": {
        "type": "Boolean",
        "value": {}
      "filter_reset": {
        "type": "Boolean",
        "value": {}
      "temp": {
        "type": "Integer",
        "value": {
          "unit": "\u2103",
          "min": -20,
          "max": 75,
          "scale": 0,
          "step": 1
      "humidity": {
        "type": "Integer",
        "value": {
          "unit": "%",
          "min": 0,
          "max": 100,
          "scale": 0,
          "step": 1
      "air_quality": {
        "type": "Enum",
        "value": {
          "range": [
            "great",
            "good",
            "mild"
      "fault": {
        "type": "Bitmap",
        "value": {
          "label": [
            "e1",
            "e2"
    "status": {
      "switch": true,
      "pm25": 5,
      "mode": "auto",
      "filter": 13,
      "anion": true,
      "lock": false,
      "filter_reset": false,
      "temp": 20,
      "humidity": 42,
      "air_quality": "great",
      "fault": 0
    "home_assistant": {
      "name_by_user": null,
      "disabled": false,
      "entities": [
          "disabled": false,
          "entity_category": null,
          "device_class": null,
          "original_device_class": null,
          "icon": null,
          "original_icon": null,
          "unit_of_measurement": null,
          "state": {
            "entity_id": "fan.klarta_forste_4_b",
            "state": "on",
            "attributes": {
              "preset_modes": [
                "auto",
                "manual",
                "sleep"
              "preset_mode": "auto",
              "friendly_name": "Klarta Forste 4 B",
              "supported_features": 56
            "last_changed": "2025-02-09T11:03:59.228601+00:00",
            "last_reported": "2025-02-09T11:05:02.742330+00:00",
            "last_updated": "2025-02-09T11:04:04.171426+00:00"
          "disabled": false,
          "entity_category": "diagnostic",
          "icon": null,
          "unit_of_measurement": "%",
          "state": {
            "entity_id": "sensor.klarta_forste_4_b_filter_utilization",
            "state": "13.0",
            "attributes": {
              "friendly_name": "Klarta Forste 4 B Filter utilization"
            "last_changed": "2025-02-09T10:58:15.683968+00:00",
            "last_reported": "2025-02-09T11:05:02.742476+00:00",
            "last_updated": "2025-02-09T10:58:15.683968+00:00"
          "disabled": false,
          "icon": null,
          "state": {
            "entity_id": "sensor.klarta_forste_4_b_pm2_5",
            "state": "5.0",
            "attributes": {
              "state_class": "measurement",
              "friendly_name": "Klarta Forste 4 B PM2.5"
            "last_changed": "2025-02-09T11:05:02.742541+00:00",
            "last_reported": "2025-02-09T11:05:02.742541+00:00",
            "last_updated": "2025-02-09T11:05:02.742541+00:00"
          "disabled": false,
          "original_device_class": "temperature",
          "icon": null,
          "unit_of_measurement": "\u00b0C",
          "state": {
            "entity_id": "sensor.klarta_forste_4_b_temperature",
            "state": "20.0",
            "attributes": {
              "device_class": "temperature",
              "friendly_name": "Klarta Forste 4 B Temperature"
            "last_changed": "2025-02-09T10:58:15.684673+00:00",
            "last_reported": "2025-02-09T11:05:02.742752+00:00",
            "last_updated": "2025-02-09T10:58:15.684673+00:00"
          "disabled": false,
          "original_device_class": "humidity",
          "icon": null,
          "state": {
            "entity_id": "sensor.klarta_forste_4_b_humidity",
            "state": "42.0",
            "attributes": {
              "device_class": "humidity",
              "friendly_name": "Klarta Forste 4 B Humidity"
            "last_changed": "2025-02-09T11:04:23.139987+00:00",
            "last_reported": "2025-02-09T11:05:02.742834+00:00",
            "last_updated": "2025-02-09T11:04:23.139987+00:00"
          "disabled": false,
          "icon": null,
          "state": {
            "entity_id": "sensor.klarta_forste_4_b_air_quality",
            "state": "great",
            "attributes": {
              "friendly_name": "Klarta Forste 4 B Air quality"
            "last_changed": "2025-02-09T11:04:10.405506+00:00",
            "last_reported": "2025-02-09T11:05:02.742884+00:00",
            "last_updated": "2025-02-09T11:04:10.405506+00:00"
          "disabled": false,
          "entity_category": "config",
          "icon": null,
          "state": {
            "entity_id": "switch.klarta_forste_4_b_ionizer",
            "state": "on",
            "attributes": {
              "friendly_name": "Klarta Forste 4 B Ionizer"
            "last_changed": "2025-02-09T10:58:15.694923+00:00",
            "last_reported": "2025-02-09T11:05:02.742930+00:00",
            "last_updated": "2025-02-09T10:58:15.694923+00:00"
          "disabled": false,
          "icon": null,
          "state": {
            "entity_id": "switch.klarta_forste_4_b_filter_cartridge_reset",
            "state": "off",
            "attributes": {
              "friendly_name": "Klarta Forste 4 B Filter cartridge reset"
            "last_changed": "2025-02-09T10:58:15.695216+00:00",
            "last_reported": "2025-02-09T11:05:02.742970+00:00",
            "last_updated": "2025-02-09T10:58:15.695216+00:00"
          "disabled": false,
          "icon": null,
          "state": {
            "entity_id": "switch.klarta_forste_4_b_child_lock",
            "state": "off",
            "attributes": {
              "friendly_name": "Klarta Forste 4 B Child lock"
            "last_changed": "2025-02-09T10:58:15.695794+00:00",
            "last_reported": "2025-02-09T11:05:02.743006+00:00",
            "last_updated": "2025-02-09T10:58:15.695794+00:00"
          "disabled": false,
          "icon": null,
          "state": {
            "entity_id": "switch.klarta_forste_4_b_power",
            "state": "on",
            "attributes": {
              "friendly_name": "Klarta Forste 4 B Power"
            "last_changed": "2025-02-09T11:03:59.229445+00:00",
            "last_reported": "2025-02-09T11:05:02.743041+00:00",
            "last_updated": "2025-02-09T11:03:59.229445+00:00"
    "set_up": true,
    "support_local": true
I think a Tap-to-Run scene in the Smart Life app will help. It is a visible and controllable entity in the HA Tuya integration (Cloud).
