Tuya Integration - No Devices?
Hi, I got some devices that are unfortunately not able to be flashed with tuya-convert
For now, Ill have to use them on the Tuya platform
For some reason, i cannot get the Tuya integration to work, I can add the account okay, i fill out user, pass, country code and select tuya as the application, it then adds without error but no devices get pulled down
Ive tried
  • Issuing the fetch devices command
  • remove and re-add the integration
  • restarting my HAS server
  • adding the integration via mobile number instead of email
Nothing seems to work, no devices show, thought adding scenes within the app seems to work fine
I only have two RGB bulbs in the tuya system, but they fail to show
Then you are unlucky, it seems your bulbs are unsupported. Normally, your scenes should be available in HA.
