So im just using the tuya cloud integration (https://www.home-assistant.io/integrations/tuya/) and I see my tuya smart switches show up as entities but I cannot link entities, which I can turn on and off manually, but I cannot create devices out of them to use in integrations.
I have tried using localtuya as well But I can’t get that to work either.
Any help or suggestions on the easiest way to integrate with tuya smart switches would be appreciate.
I am definitely willing to flash the switches if need be as well.
Often they are identical devices made from different company. Look at the pictures of the devices and see if one is identical to yours. If there is noneone, there’s a good chance the guts inside are the same.
Edit, oops, said none instead one, kinda the opposite of what I was trying to say…
If you have auto discovery turned on and MQTT enabled, open up the console on your Tasmota device and type:
setoption19 1
This will make your switch appear under MQTT in the Integration tab. That’s how I did it. You can also turn on Belkin Wemo or Hue Bridge emulation from ‘Configuration / Configure Other’ page.
