I am having an issue getting the Tuya integration to work. I can’t seem to get the integration to accept my credentials.
I enter in my username, password, country code (353 - Ireland) and select tuya as app option and I just get “Invalid authentication”. I can’t see anything in the logs that might hint at the cause. I am successfully able to log into the Tuya portal as well as the phone app.
Is there any suggestions to get my Tuya devices configured within Home Assistant
I am entering my email address as that is what I am using to log into the Tuya app and Website. I have also tried phone number but doesn’t seem to make a different. I have also tried setting up a SmartLife account and again no difference in behaviour
I have version 113.3. Does anyone even have integration working? I tried both the “tuya” profile and the “smart life” profile (I used the appropriate applications). In any case, the authorization is incorrect
I have decided to raise a support ticket as it doesn’t appear that i have done something wrong if others are getting similar issues. Here is the support ticket https://github.com/home-assistant/core/issues/38724
I fixed this by creating a new simple account with another email, earlier I was signing in with Google and experiencing this issue. I guess if you sign in with Google then the username is not your email.
I had the same issue (Invalid authentication). The fix that worked for me was to create a new account with my yahoo email and a 10 digit alpha numeric (no symbols) password.
I have follow your suggestion @Cleverson_Sacramento. After add sms notification in SmartLife app i can use my phone number as username.
In smartlife, it show my username like this : 33-06XXXXXXXX.
In HA, i use 06XXXXXXXX and 33 as country code and it’s works.
