Tuya Integration setup failure - Invalid authentication
I figured out that it only has problem with @gmail.com e-mail address for some reason. With hotmail.com and my country code works like a charm.
I tried every suggestion. nothing worked.
I do not use hotmail or gmail. normal email account and project setup correctly. devices show in the tuya iot platform. And I am able to see them in the app also. Incl. the tuya iot integration.
tried both entering the access id and secret manually and copy/paste.
seems like the integration is broken
Same shit here since long ago, one update and was no working anymore, updated to V2 via hacs and tried anything and bored of it now.
Good luck
I just solve the error with Tuya V2 Integration validation with one change in a file.
The problem is that in the file ‘config_flow.py’ (inside custom/components/tuya_v2) there ir this constant:
TUYA_ENDPOINT_OTHER = “https openapi tuyaaus com”
For that, it only admit if you are register in China or Australia.
Changing that for the correct endpoint, it works after a system restart.
I found the endpoint here: https:// github.com /tuya /tuya-home-assistant/ blob /main /docs/regions_dataCenters.md
I found this solve in this thread: ( [zlinoliver] commented on 22 Oct
This solution worked for me with country code 46.
Thank you for sharing, this is the solution, I changed the URL to the Data Centre I am using and I could authenticate.
I was also having the same issue. It looks like an old or partial install of Tuya 2.0 was present. I fixed it by going in to the file editor, finding the sub folder tuya_v2 in the custom components folder and renaming it a xtuya_v2. I then restarted HA.
After the restart I then did an add integration of tuya v2 and it worked!!!
Bless you man, that worked for me too. Thank you
Until I had to log in to say thanks.
Damn how much time I spent solving this and it’s so trivial. THANK YOU VERY MUCH!!!
