Hi!
I have a smart towel rack, connected to the tuya envionment. It has several exposed actions/sensors (power on, timer, set and current temperature, etc). I want to automate it’s functions (for example turn it on when i’m producing more solar power that what i’m consuming, maybe increasing the target temperature).
This is the diagnostic log:
"home_assistant": {
"installation_type": "Home Assistant OS",
"version": "2023.12.0",
"dev": false,
"hassio": true,
"virtualenv": false,
"python_version": "3.11.6",
"docker": true,
"arch": "aarch64",
"timezone": "Europe/Rome",
"os_name": "Linux",
"os_version": "6.1.58-haos-raspi",
"supervisor": "2023.11.6",
"host_os": "Home Assistant OS 11.2",
"docker_version": "24.0.7",
"chassis": "embedded",
"run_as_root": true
"custom_components": {
"hacs": {
"version": "1.33.0",
"requirements": [
"aiogithubapi>=22.10.1"
"integration_manifest": {
"domain": "tuya",
"name": "Tuya",
"codeowners": [
"@Tuya",
"@zlinoliver",
"@frenck"
"config_flow": true,
"dependencies": [
"ffmpeg"
"dhcp": [
"macaddress": "xxxx*"
"documentation": "https://www.home-assistant.io/integrations/tuya",
"integration_type": "hub",
"iot_class": "cloud_push",
"loggers": [
"tuya_iot"
"requirements": [
"tuya-iot-py-sdk==0.6.6"
"is_built_in": true
"data": {
"endpoint": "https://openapi.tuyaeu.com",
"auth_type": 0,
"country_code": "39",
"app_type": "tuyaSmart",
"mqtt_connected": true,
"disabled_by": null,
"disabled_polling": false,
"name": "Portasciugamani intelligente",
"model": "119",
"category": "mjj",
"product_id": "yghsoyzoicezv8sy",
"product_name": "Smart Towel Rack",
"online": true,
"sub": false,
"time_zone": "+01:00",
"active_time": "2023-12-07T19:10:50+00:00",
"create_time": "2023-12-07T19:10:50+00:00",
"update_time": "2023-12-07T19:10:53+00:00",
"function": {
"switch": {
"type": "Boolean",
"value": {}
"temp_set": {
"type": "Integer",
"value": {
"unit": "\u2103",
"min": 30,
"max": 70,
"scale": 0,
"step": 5
"countdown_set": {
"type": "Enum",
"value": {
"range": [
"cancel",
"1h",
"2h",
"3h",
"4h",
"5h",
"6h"
"status_range": {
"switch": {
"type": "Boolean",
"value": {}
"temp_set": {
"type": "Integer",
"value": {
"unit": "\u2103",
"min": 30,
"max": 70,
"scale": 0,
"step": 5
"temp_current": {
"type": "Integer",
"value": {
"unit": "\u2103",
"min": 0,
"max": 90,
"scale": 0,
"step": 1
"countdown_set": {
"type": "Enum",
"value": {
"range": [
"cancel",
"1h",
"2h",
"3h",
"4h",
"5h",
"6h"
"countdown_left": {
"type": "Integer",
"value": {
"unit": "min",
"min": 0,
"max": 1440,
"scale": 0,
"step": 1
"work_state": {
"type": "Enum",
"value": {
"range": [
"heating",
"standby"
"status": {
"switch": true,
"temp_set": 55,
"temp_current": 54,
"countdown_set": "cancel",
"countdown_left": 22,
"work_state": "standby"
"home_assistant": {
"name_by_user": null,
"disabled": false,
"entities": []
As can be seen at the end of the diagnostic log, all the functions are exposed.
How i can “implement” this function in home assistant?
Thanks!
