Hi!
I simply can’t get my Svive wifi led stripe to stay connected to my wifi. I have checked the code, the entity name, reconnected it via the Tuya integration and the Smart Life app. Sometimes it works for a couple of minutes but then it disconnects. The interesting thing is that when I connect to it via the Smart Life app it’s not connected but connects within a couple of seconds. Ti’s like it goes into some kind of sleep mode where it only can be called by the Smart Life app. I have tried to reload the Tuya integration and to restart the Home Assistent server.
Below is the floorplan card code:
title: Övervåning
type: picture-elements
image: /local/floorplan2.jpg
elements:
- type: image
entity: light.rgb_lampa_1
tap_action:
action: toggle
image: local/light_bulb_off.png
state_image:
'on': local/light_bulb_on.png
state_filter:
'on': brightness(130%) saturate(1.5) drop-shadow(0px 0px 10px gold)
'off': brightness(80%) saturate(0.8)
style:
top: 45%
left: 81%
width: 7%
padding: 1px
- type: image
entity: light.rgb_ledlist
tap_action:
action: toggle
image: local/led_strip_off.png
state_image:
'on': local/led_strip_on.png
state_filter:
style:
top: 47%
left: 71%
width: 6%
padding: 1px
Below is the entity card code:
type: vertical-stack
cards:
- type: entities
entities:
- entity: switch.fonsterlampa
- entity: light.rgb_lampa_1
- entity: light.rgb_ledlist
state_color: true
show_header_toggle: false
Below is my entities view where “inte tillgänglig” means “not available”.
Below is the logginformation:
Logger: homeassistant.components.light.reproduce_state
Source: components/light/reproduce_state.py:131
Integration: Lampor (documentation, issues)
First occurred: 13 januari 2022 19:37:30 (8 occurrences)
Last logged: 13 januari 2022 19:41:50
Invalid state specified for light.rgb_ledlist: unavailable
