Hi.
I have problem, I think because I did not make research properly before buying stuff. I want to use double click function on switch showed in Zigbee2MQTT as TS0011. Inside there is a chip TYZ3S.
Is anyone of You guys have solution to do that? Or maybe there is alternative firmware that’s working on that switch?
