I am wondering if anyone smarter than myself can help with getting this working at all please?
I have the ASAKUKI Smart Oil Diffuser running Tuya, it’s too new to allow me to flash it with ESP Home so I am limited to using Tuya Local, I’ve managed to get master control on/off and off/weak/strong for the diffuser side of things, my settings are below if anyone wants them:
Main on/off is value 1:
And the diffuser mist control is 103, you need to set this up as Select entity and the options are
off;small;big
and these link to Off, Weak, and Strong
The issue I have is in trying to control the light on it, I can’t seem to figure out which of the options do what, I thought I figured it out at one point but turns out I was wrong, I’ve taken some snapshots based on what it’s doing and this is what I’ve gotten:
I’d be happy with just being able to control the nightlight function, at one point I did manage to change the brightness and the colour but it wasn’t happy and then freaked out requiring it to be power cycled and setup in Tuya Local again.
If I setup option 11 as an on/off switch I can turn the light on and off but it forgets it’s previous state
Anyone got any ideas maybe?
N/B update, I’ve managed to figure out that value 110 is to control the light style, these are
1;2;3
Which lines up to Gradient, Solid, Night light
And I suspect value 108 controls the colour in RGBHSV mode, but I am happy with gradient and night light, would be nice to control the colour so I can tie it in with the rest of the lights in my room
Does anyone have more information on how to configure the diffusor? I’m currently struggling to get it going. It ain’t even recognized and since this is the first Tuya based device I am about to add, I don’t really know how to configure it manually.
I got one of these recently and this is my experience:
If you use the power switch to turn it off and on, it will always come back on with mist=weak and light-gradient. This is independent of any integration and happens through the Tuya Smart app too.
The Tuya Local integration (make-all) cannot control the color, but the Local Tuya integration (rospogrigio) can.
Like many Tuya devices I found it very regularly goes unavailable for a few seconds. After this happens changing the color in HA or the Tuya Smart app causes it to flash that color, but revert to whatever it was. I had to set the mode to “Solid” again to be able to select a color.
For me the Tuya Local integration did not update the color value as implied by the OP’s screen shots. Instead I used the API Explorer in the Tuya iOT Platform webpage and called “Query Properties” for the device, which is under “Device Control”. I then changed to a bunch of colors and did a copy-paste of the colour_data. The values I used are below.
The light intensity entity is confusing. If you set the intensity through Tuya Smart it updates the color, not this field. But if you do set the intensity entity it does change the brightness on the device. I resolved upon setting the intensity within color names.
Today I noticed that I was getting 20,000 errors in the log from Local Tuya (rospogrigio)
Exception in callback _SelectorDatagramTransport._read_ready()
It seems there’s a lot of open issues like this. I tried switching back to Tuya Local (make-all) which is where all my other Tuya devices live, but it was getting an error connecting as I had originally. On a whim I tried connecting with a normal 2.4GHz wifi rather than the mesh 2.4GHz wifi that I normally use, and this worked. It recognised it as a Ditua diffuser, and this set up better than with the rospogrigio version (proper fan and light entities).
This is great and works so far. If you set an automation with turning an, select light mode and color, you have to put like 0,5 seconds delay between the events.
Is there any chance to convert that color picker to an RGB-picker like “normal” RGB-lights have in HA? Like a template? Because i want to integrate this into my HA as an RGB-light.
Thanks for all the great info!
Does anyone have any data for the Fault sensor (12)?
I’d like to be able to detect when the device is out of water.
If you try starting it from the Tuya App with no water in you get an error pop-up so I assume that the Fault sensor can detect this…
13 is a timer that can be set to On,1 hour, 3 hour, 6 hour
select
Timer
0;1;2;3
Off;1 Hour;3Hour;6 Hour
14 is just a minute counter for that timer.
Sensor
Timer Minutes
minutes
enum
being that there we are using home assistant, these probably aren’t the most useful but i wanted to add them for completeness sake.
still cant figure out what 109 is. I cant get it to change from an output of white and dont know how to really monitor a char variable through home assistant.
