Tuya Local DImmer light switch does not dimm
I set up my dimmer with Local Tuya
On/off works, but when I dimm I get:
Failed to call service light/turn_on. object of type 'NoneType' has no len()
"status": [
        "code": "switch_led_1",
        "value": true
        "code": "bright_value_1",
        "value": 1000
        "code": "brightness_min_1",
        "value": 1000
        "code": "led_type_1",
        "value": "halogen"
Please help to make the dimming work
Did you ever figure out your problem as i seem to be having the same issue.
no i gave up
