It is just stuck on this screen. I did restart my HA as well but same issue.
Check logs and fix the issue or
Do a manual update ?
Installation:
The easiest way, if you are using HACS, is to install LocalTuya through HACS.
For manual installation, copy the localtuya folder and all of its contents into your Home Assistant’s custom_components folder. This folder is usually inside your /config
folder. If you are running HassOS, use SAMBA to copy the folder over. If you are running Home Assistant Supervised, the custom_components folder might be located at /usr/share/hassio/homeassistant
. You may need to create the custom_components
folder and then copy the localtuya folder and all of its contents into it.
source:GitHub - rospogrigio/localtuya: local handling for Tuya devices
Could be simply Github rate limiting, and working in a few hours.
Thank you. I will try this.
It’s been few days and it is not updating. Same issue.
