I need some help with a couple of RGBW light strips.
They are currently setup as below. I can change the color fine and clicking the white in the center seems to set it to white correctly, I just can’t turn it off.
When I try to turn it off HA shows it off but the light just changes to white.
I am not sure what I am missing
You should probably have picked 1 as ID when you created the light. Try removing the entity and adding it again.
Son of a gun.
That fixed it. Thanks so much.
