I don’t know which is the easiest way since I still haven’t tried the Node-red method, but my impression is that the localtuya integration should be easier to setup, you just have to add the custom repository. The hard part (for both methods) is to get the devId and localKey of your devices, there are several ways to obtain them, you just have to find the method that suits you best.
I don’t think these methods will be integrated in HA unless some skilled developer takes them in charge, and also because the support (for localtuya) is currently limited to a couple of devices (covers and switches/smart plugs) and it lacks the support for a lot of other devices (light bulbs, etc…).
Hope the above answers your question, bye!
Only had to struggle for a whole day but I got it to work
Hello, @rospogrigio
Thanks for Your work and module for Home Assistant.
I have bought 4 Smart Plugs which are connected to Tuya. Is was build on W600 (not esp8266) and there is no any methods to flash to esphome.
But with Your localtuya-homeassistant I have successfully intergrate Smart Plugs with Power Monitor and have blocked all traffic to chinese servers on MikroTik.
Device ID and Device Key was obtained via Bluestacks with Root and Smart Life v 3.3.0
Hello, I am brand new to home assistant and love the idea of controlling my tuya dimmer switches locally. Using localtuya, I can get them to show up as entities in home assistant, but I cannot get or change their status. I keep running into “This entity does not have a unique ID, therefore its settings cannot be managed from the UI.” I feel like I am missing something and would appreciate any help with this problem.
@OfWonder If you are adding your switches through confi.yaml you can’t manage your entities through the UI. There is no error here, just a message letting you know that is how it will be.
Sagar,
How do I change the state of the light switch? In the video linked below, he uses Lovelace to turn his switch on and off.
Error while setting up localtuya platform for switch
File “/home/homeassistant/.homeassistant/custom_components/localtuya/pytuya/init.py”, line 24, in
import Crypto
ModuleNotFoundError: No module named ‘Crypto’
I have a Gosund smart power strip (3 sockets + 3 usb), but I can’t get it to work.
After inserting the localtuya folder (from the @rospogrigio repository), finding the keys and entering this code in the switch.yaml file, home assistant does not see any of these entity.
The power strip work with this method?
- platform: localtuya
host: 192.168.0.88
local_key: !secret mylocalkey
device_id: !secret mydeviceid
friendly_name: ciabatta_smart
protocol_version: 3.1
switches:
sw01:
friendly_name: Presa 1
current: 18
current_consumption: 19
voltage: 20
sw02:
friendly_name: Presa 2
sw03:
friendly_name: Presa 3
sw04:
friendly_name: USB Plug
Update: This is the error in the log:
File "/config/custom_components/localtuya/switch.py", line 160, in __get_status
status = self._device.status()
File "/config/custom_components/localtuya/pytuya/__init__.py", line 324, in status
data = self._send_receive(payload)
File "/config/custom_components/localtuya/pytuya/__init__.py", line 194, in _send_receive
raise e
File "/config/custom_components/localtuya/pytuya/__init__.py", line 191, in _send_receive
s.connect((self.address, self.port))
socket.timeout: timed out
File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 184, in _async_setup_platform
await asyncio.shield(task)
File "/usr/local/lib/python3.8/concurrent/futures/thread.py", line 57, in run
File "/config/custom_components/localtuya/switch.py", line 104, in setup_platform
TuyaDevice(
File "/config/custom_components/localtuya/switch.py", line 210, in __init__
self._status = self._device.status()
File "/config/custom_components/localtuya/switch.py", line 191, in status
self._cached_status = self.__get_status()
File "/config/custom_components/localtuya/switch.py", line 168, in __get_status
raise ConnectionError("Failed to update status .")
ConnectionError: Failed to update status .
The problem is that “timed out” message: the device does not respond for a lot of time (30s as far as I remember). This is probably due to one of these situations:
- wrong deviceId/localKey : double check these values
- (less likely) faulty connection: try to move the device closer to the access point and see if it works
- the device uses a different communication protocol: I see you are using 3.1, try to set 3.3 (which is the default and I believe, mostly used). If neither works, maybe the Tuya guys have defined a new protocol so some changes in the code might be needed.
I have ordered a smart power strip too, I will receive it at the end of September hopefully: if I bump in the same problems I will try to fix them and give feedback.
Bye,
rospogrigio
Ok, It’s work thanks @rospogrigio. I change the wrong parameter (IP and protocol) and now working.
consumption data are updated with a delay of about fifteen seconds, but that’s just fine, volts and watts are correct.
For those who use the rospogrigio repo, the instructions in the video linked by OfWonder are correct and easy to apply.
- install android emulator for pc
- install Es File Explorer
- install Smart Life version 3.6.1
- Extract the keys and put them in configuration.yaml or dedicated files
- GO
@byxil I see most peoiple using this for sockets. Has anyone gotten it to work with light switches? My switches are linked below, and I just cannot get them to work. If anyone could give me some pointers on this I would really appreciate it.
Switch Link: https://www.amazon.com/gp/product/B07K67D43J/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
from the link you put, it seems to me a normal dimmable switch, does it also have consumption?
if it does not have consumption, you can try to insert it in the home assistant with the official tuya integration, from Settings, Integrations, new integration, tuya
I was wondering the same thing… I tried adding a light since there is a light.py in the integration, but didn’t get very far. @rospogrigio do you know if the light integration should be working?
@byxil I can get them to function with the official Tuya integration, but I would really like local control without the need to remove them from the walls to flash them all with Tasmota.
Hi @rospogrigio (or anyone else), I have been trying to get your fork of localtuya to work with my cover device, which is an automatic roller shade (see https://www.aliexpress.com/item/4001045079168.html?). I am a novice coder myself, so i’ve taken just about every step I know how to try and get the cover to work, but to no avail. I also don’t see anyone else on here that’s posted about setting up a cover. Any help would be greatly appreciated.
I have successfully extracted the Key & ID. I am also able to communicate with the device using tuya-cli. I can both get the data and set the data with no issues. This makes me confident that there are no issues with my device, and it should be possible to communicate with it using your localtuya fork. For reference, I can run the following command using tuya-cli to get the following dps data:
tuya-cli get --id xxxxxxxxxxxxxxxxxxxx --key xxxxxxxxxxxxxxxx --protocol-version 3.3 --all
dps: {
'1': 'close',
'2': 40,
'3': 100,
'5': false,
'7': 'closing',
'8': 'cancel',
'9': 0,
'10': 0,
'11': 38610
Setting ‘2’ allows me to control the position, from 0 to 100.
However, I am unable to get the cover connected with localtuya. First, I did make one change to “cover.py” to align with the device’s dps.
dps[config.get(CONF_ID)]=None
dps["1"]=None
dps["2"]=None
dps["3"]=None
dps["5"]=None
dps["7"]=None
dps["8"]=None
dps["9"]=None
dps["10"]=None
dps["11"]=None
Next, here is my config file:
#Enable local tuya integration https://github.com/rospogrigio/localtuya-homeassistant
cover:
host: 192.168.1.29
local_key: xxxxxxxxxxxxxxxx
device_id: xxxxxxxxxxxxxxxxxxxx
friendly_name: Left Blind Local
protocol_version: 3.3
I also added extensive logging throughout cover.py and __init__.py
, which I hope can be helpful in trying to diagnose this problem. Here are my logs:
2020-09-01 23:20:46 WARNING (MainThread) [homeassistant.loader] You are using a custom integration for localtuya which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant.
2020-09-01 23:20:47 INFO (MainThread) [homeassistant.components.cover] Setting up cover.localtuya
2020-09-01 23:20:47 DEBUG (SyncWorker_8) [custom_components.localtuya.pytuya] custom_components.localtuya.pytuya version 7.0.8
2020-09-01 23:20:47 DEBUG (SyncWorker_8) [custom_components.localtuya.pytuya] Python 3.8.3 (default, Jul 10 2020, 18:54:27)
[GCC 9.3.0] on linux
2020-09-01 23:20:47 DEBUG (SyncWorker_8) [custom_components.localtuya.pytuya] Using PyCrypto (3, 9, '8')
2020-09-01 23:20:47 DEBUG (SyncWorker_8) [custom_components.localtuya.pytuya] Using PyCrypto from '/usr/local/lib/python3.8/site-packages/Crypto/__init__.py'
2020-09-01 23:20:47 INFO (SyncWorker_8) [custom_components.localtuya.cover] ('xxxxxxxxxxxxxxxxxxxx', '192.168.1.29')
2020-09-01 23:20:47 INFO (SyncWorker_8) [custom_components.localtuya.cover] trying def status(self)
2020-09-01 23:20:47 INFO (SyncWorker_8) [custom_components.localtuya.cover] self._cached_status after sleep =
2020-09-01 23:20:47 INFO (SyncWorker_8) [custom_components.localtuya.cover] self.__get_status after sleep = <bound method TuyaCoverCache.__get_status of <custom_components.localtuya.cover.TuyaCoverCache object at 0xaf25edc0>>
2020-09-01 23:20:47 INFO (SyncWorker_8) [custom_components.localtuya.cover] about to attempt status=self._device.status()
2020-09-01 23:20:47 DEBUG (SyncWorker_8) [custom_components.localtuya.pytuya] logger debug running from def status(self)
2020-09-01 23:20:47 DEBUG (SyncWorker_8) [custom_components.localtuya.pytuya] status() entry (dev_type is device22)
2020-09-01 23:20:47 DEBUG (SyncWorker_8) [custom_components.localtuya.pytuya] json_payload=b'{"devId":"xxxxxxxxxxxxxxxxxxxx","uid":"xxxxxxxxxxxxxxxxxxxx","t":"1599027647","dps":{"1":null,"2":null,"3":null,"5":null,"7":null,"8":null,"9":null,"10":null,"11":null}}'
2020-09-01 23:20:47 DEBUG (SyncWorker_8) [custom_components.localtuya.pytuya] payload is b'\x00\x00U\xaa\x00\x00\x00\x00\x00\x00\x00\r\x00\x00\x00\xc73.3\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00H7L6\xf0\xd4\xcc\x11f\x8e\xbaI\xd1\xf1\x19%\x89m\xe8cB\xd6\x9cI\t8#\x8b\x1f\x1a\x07\x91c*d\xf3oI\xdc\x836\x15\x08J\x8a\x87RX4\x92\xd8q\x10\xc2\x00\xa8\xc8\xb0\xb1\xf6\x81Td\xce\'G(\x82|z"\xfd*\xc3\x17\x18\x16\xf5w\x0f\x0b]\x9dDU+]SB\xcb\x1b\x17\xe0\r=\xcc\xce\x8f;\x8b\n\x85\xc1\xab"\x92\xc7\xe9\x86~j-\xf4\xe8\xd1T\x17\x83\xd7\x9b\x80iwP\x9f\xcbMD\xd1\xbe\xfc//7\x84G\xb6W_\x07\xc2\xbf\ns\x1eG\xa7x\xfb\xbc+N\xb7\xd8\xd3TLu\x981\xcc\xab\xc6o\xceg\xd4\xba@"C\x96N\xbd\xc8\x00\xb8\x85\xac/\x00\x00\xaaU'
2020-09-01 23:20:47 DEBUG (SyncWorker_8) [custom_components.localtuya.pytuya] debugging from _send_receive try
2020-09-01 23:20:47 DEBUG (SyncWorker_8) [custom_components.localtuya.pytuya] s variable set to = <socket.socket fd=40, family=AddressFamily.AF_INET, type=SocketKind.SOCK_STREAM, proto=0, laddr=('192.168.1.56', 34174)>
2020-09-01 23:20:47 DEBUG (SyncWorker_8) [custom_components.localtuya.pytuya] self.connection_timeout is 10)
2020-09-01 23:20:47 DEBUG (SyncWorker_8) [custom_components.localtuya.pytuya] self.address is 192.168.1.29)
2020-09-01 23:20:47 DEBUG (SyncWorker_8) [custom_components.localtuya.pytuya] self.port is 6668)
2020-09-01 23:20:47 DEBUG (SyncWorker_8) [custom_components.localtuya.pytuya] about to connect using address and port
2020-09-01 23:20:47 DEBUG (SyncWorker_8) [custom_components.localtuya.pytuya] about to send payload from try b'\x00\x00U\xaa\x00\x00\x00\x00\x00\x00\x00\r\x00\x00\x00\xc73.3\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00H7L6\xf0\xd4\xcc\x11f\x8e\xbaI\xd1\xf1\x19%\x89m\xe8cB\xd6\x9cI\t8#\x8b\x1f\x1a\x07\x91c*d\xf3oI\xdc\x836\x15\x08J\x8a\x87RX4\x92\xd8q\x10\xc2\x00\xa8\xc8\xb0\xb1\xf6\x81Td\xce\'G(\x82|z"\xfd*\xc3\x17\x18\x16\xf5w\x0f\x0b]\x9dDU+]SB\xcb\x1b\x17\xe0\r=\xcc\xce\x8f;\x8b\n\x85\xc1\xab"\x92\xc7\xe9\x86~j-\xf4\xe8\xd1T\x17\x83\xd7\x9b\x80iwP\x9f\xcbMD\xd1\xbe\xfc//7\x84G\xb6W_\x07\xc2\xbf\ns\x1eG\xa7x\xfb\xbc+N\xb7\xd8\xd3TLu\x981\xcc\xab\xc6o\xceg\xd4\xba@"C\x96N\xbd\xc8\x00\xb8\x85\xac/\x00\x00\xaaU'
2020-09-01 23:20:47 DEBUG (SyncWorker_8) [custom_components.localtuya.pytuya] about to try for data=s.recv(1024)
2020-09-01 23:20:57 WARNING (MainThread) [homeassistant.components.cover] Setup of cover platform localtuya is taking over 10 seconds.
2020-09-01 23:20:57 DEBUG (SyncWorker_8) [custom_components.localtuya.pytuya] failed to receive data, raising e exception
2020-09-01 23:20:58 WARNING (MainThread) [homeassistant.components.switch] Setup of switch platform tplink is taking over 10 seconds.
2020-09-01 23:20:58 INFO (SyncWorker_8) [custom_components.localtuya.cover] about to attempt status=self._device.status()
2020-09-01 23:20:58 DEBUG (SyncWorker_8) [custom_components.localtuya.pytuya] logger debug running from def status(self)
2020-09-01 23:20:58 DEBUG (SyncWorker_8) [custom_components.localtuya.pytuya] status() entry (dev_type is device22)
2020-09-01 23:20:58 DEBUG (SyncWorker_8) [custom_components.localtuya.pytuya] json_payload=b'{"devId":"xxxxxxxxxxxxxxxxxxxx","uid":"xxxxxxxxxxxxxxxxxxxx","t":"1599027658","dps":{"1":null,"2":null,"3":null,"5":null,"7":null,"8":null,"9":null,"10":null,"11":null}}'
2020-09-01 23:20:58 DEBUG (SyncWorker_8) [custom_components.localtuya.pytuya] payload is b'\x00\x00U\xaa\x00\x00\x00\x00\x00\x00\x00\r\x00\x00\x00\xc73.3\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00H7L6\xf0\xd4\xcc\x11f\x8e\xbaI\xd1\xf1\x19%\x89m\xe8cB\xd6\x9cI\t8#\x8b\x1f\x1a\x07\x91c*d\xf3oI\xdc\x836\x15\x08J\x8a\x87RX4\x92\xd8q\x10\xc2\x00\xa8\xc8\xb0\xb1\xf6\x81Td\xce\xf7\x02Ww\x8clo\x99,\xc4\xb6d\xf5\xb5\xd1\xe1\x0b]\x9dDU+]SB\xcb\x1b\x17\xe0\r=\xcc\xce\x8f;\x8b\n\x85\xc1\xab"\x92\xc7\xe9\x86~j-\xf4\xe8\xd1T\x17\x83\xd7\x9b\x80iwP\x9f\xcbMD\xd1\xbe\xfc//7\x84G\xb6W_\x07\xc2\xbf\ns\x1eG\xa7x\xfb\xbc+N\xb7\xd8\xd3TLu\x981\xcc\xab\xc6o\xceg\xd4\xba@"C\x96N\xbd\xc8\x00\xfd\xaf-\x99\x00\x00\xaaU'
2020-09-01 23:20:58 DEBUG (SyncWorker_8) [custom_components.localtuya.pytuya] debugging from _send_receive try
2020-09-01 23:20:58 DEBUG (SyncWorker_8) [custom_components.localtuya.pytuya] s variable set to = <socket.socket fd=40, family=AddressFamily.AF_INET, type=SocketKind.SOCK_STREAM, proto=0, laddr=('192.168.1.56', 34396)>
2020-09-01 23:20:58 DEBUG (SyncWorker_8) [custom_components.localtuya.pytuya] self.connection_timeout is 10)
2020-09-01 23:20:58 DEBUG (SyncWorker_8) [custom_components.localtuya.pytuya] self.address is 192.168.1.29)
2020-09-01 23:20:58 DEBUG (SyncWorker_8) [custom_components.localtuya.pytuya] self.port is 6668)
2020-09-01 23:20:58 DEBUG (SyncWorker_8) [custom_components.localtuya.pytuya] about to connect using address and port
2020-09-01 23:20:59 INFO (MainThread) [homeassistant.components.sensor] Setting up sensor.upnp
2020-09-01 23:20:59 DEBUG (SyncWorker_8) [custom_components.localtuya.pytuya] about to send payload from try b'\x00\x00U\xaa\x00\x00\x00\x00\x00\x00\x00\r\x00\x00\x00\xc73.3\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00H7L6\xf0\xd4\xcc\x11f\x8e\xbaI\xd1\xf1\x19%\x89m\xe8cB\xd6\x9cI\t8#\x8b\x1f\x1a\x07\x91c*d\xf3oI\xdc\x836\x15\x08J\x8a\x87RX4\x92\xd8q\x10\xc2\x00\xa8\xc8\xb0\xb1\xf6\x81Td\xce\xf7\x02Ww\x8clo\x99,\xc4\xb6d\xf5\xb5\xd1\xe1\x0b]\x9dDU+]SB\xcb\x1b\x17\xe0\r=\xcc\xce\x8f;\x8b\n\x85\xc1\xab"\x92\xc7\xe9\x86~j-\xf4\xe8\xd1T\x17\x83\xd7\x9b\x80iwP\x9f\xcbMD\xd1\xbe\xfc//7\x84G\xb6W_\x07\xc2\xbf\ns\x1eG\xa7x\xfb\xbc+N\xb7\xd8\xd3TLu\x981\xcc\xab\xc6o\xceg\xd4\xba@"C\x96N\xbd\xc8\x00\xfd\xaf-\x99\x00\x00\xaaU'
2020-09-01 23:20:59 DEBUG (SyncWorker_8) [custom_components.localtuya.pytuya] about to try for data=s.recv(1024)
2020-09-01 23:21:09 DEBUG (SyncWorker_8) [custom_components.localtuya.pytuya] failed to receive data, raising e exception
2020-09-01 23:21:10 INFO (SyncWorker_8) [custom_components.localtuya.cover] about to attempt status=self._device.status()
2020-09-01 23:21:10 DEBUG (SyncWorker_8) [custom_components.localtuya.pytuya] logger debug running from def status(self)
2020-09-01 23:21:10 DEBUG (SyncWorker_8) [custom_components.localtuya.pytuya] status() entry (dev_type is device22)
2020-09-01 23:21:10 DEBUG (SyncWorker_8) [custom_components.localtuya.pytuya] json_payload=b'{"devId":"xxxxxxxxxxxxxxxxxxxx","uid":"xxxxxxxxxxxxxxxxxxxx","t":"1599027670","dps":{"1":null,"2":null,"3":null,"5":null,"7":null,"8":null,"9":null,"10":null,"11":null}}'
2020-09-01 23:21:10 DEBUG (SyncWorker_8) [custom_components.localtuya.pytuya] payload is b'\x00\x00U\xaa\x00\x00\x00\x00\x00\x00\x00\r\x00\x00\x00\xc73.3\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00H7L6\xf0\xd4\xcc\x11f\x8e\xbaI\xd1\xf1\x19%\x89m\xe8cB\xd6\x9cI\t8#\x8b\x1f\x1a\x07\x91c*d\xf3oI\xdc\x836\x15\x08J\x8a\x87RX4\x92\xd8q\x10\xc2\x00\xa8\xc8\xb0\xb1\xf6\x81Td\xcel!k\x82\xa5\xd7 \x92\xc9\xdd\xf9\x12,\xc1\xb8\x02\x0b]\x9dDU+]SB\xcb\x1b\x17\xe0\r=\xcc\xce\x8f;\x8b\n\x85\xc1\xab"\x92\xc7\xe9\x86~j-\xf4\xe8\xd1T\x17\x83\xd7\x9b\x80iwP\x9f\xcbMD\xd1\xbe\xfc//7\x84G\xb6W_\x07\xc2\xbf\ns\x1eG\xa7x\xfb\xbc+N\xb7\xd8\xd3TLu\x981\xcc\xab\xc6o\xceg\xd4\xba@"C\x96N\xbd\xc8\x00;\xdb\xa8\xe4\x00\x00\xaaU'
2020-09-01 23:21:10 DEBUG (SyncWorker_8) [custom_components.localtuya.pytuya] debugging from _send_receive try
2020-09-01 23:21:10 DEBUG (SyncWorker_8) [custom_components.localtuya.pytuya] s variable set to = <socket.socket fd=40, family=AddressFamily.AF_INET, type=SocketKind.SOCK_STREAM, proto=0, laddr=('192.168.1.56', 34490)>
2020-09-01 23:21:10 DEBUG (SyncWorker_8) [custom_components.localtuya.pytuya] self.connection_timeout is 10)
2020-09-01 23:21:10 DEBUG (SyncWorker_8) [custom_components.localtuya.pytuya] self.address is 192.168.1.29)
2020-09-01 23:21:10 DEBUG (SyncWorker_8) [custom_components.localtuya.pytuya] self.port is 6668)
2020-09-01 23:21:10 DEBUG (SyncWorker_8) [custom_components.localtuya.pytuya] about to connect using address and port
2020-09-01 23:21:10 DEBUG (SyncWorker_8) [custom_components.localtuya.pytuya] about to send payload from try b'\x00\x00U\xaa\x00\x00\x00\x00\x00\x00\x00\r\x00\x00\x00\xc73.3\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00H7L6\xf0\xd4\xcc\x11f\x8e\xbaI\xd1\xf1\x19%\x89m\xe8cB\xd6\x9cI\t8#\x8b\x1f\x1a\x07\x91c*d\xf3oI\xdc\x836\x15\x08J\x8a\x87RX4\x92\xd8q\x10\xc2\x00\xa8\xc8\xb0\xb1\xf6\x81Td\xcel!k\x82\xa5\xd7 \x92\xc9\xdd\xf9\x12,\xc1\xb8\x02\x0b]\x9dDU+]SB\xcb\x1b\x17\xe0\r=\xcc\xce\x8f;\x8b\n\x85\xc1\xab"\x92\xc7\xe9\x86~j-\xf4\xe8\xd1T\x17\x83\xd7\x9b\x80iwP\x9f\xcbMD\xd1\xbe\xfc//7\x84G\xb6W_\x07\xc2\xbf\ns\x1eG\xa7x\xfb\xbc+N\xb7\xd8\xd3TLu\x981\xcc\xab\xc6o\xceg\xd4\xba@"C\x96N\xbd\xc8\x00;\xdb\xa8\xe4\x00\x00\xaaU'
2020-09-01 23:21:10 DEBUG (SyncWorker_8) [custom_components.localtuya.pytuya] about to try for data=s.recv(1024)
2020-09-01 23:21:20 DEBUG (SyncWorker_8) [custom_components.localtuya.pytuya] failed to receive data, raising e exception
2020-09-01 23:21:21 ERROR (SyncWorker_8) [custom_components.localtuya.cover] Failed to update status of device 192.168.1.29
2020-09-01 23:21:22 ERROR (MainThread) [homeassistant.components.cover] Error while setting up localtuya platform for cover
File "/config/custom_components/localtuya/cover.py", line 117, in __get_status
File "/config/custom_components/localtuya/pytuya/__init__.py", line 338, in status
File "/config/custom_components/localtuya/pytuya/__init__.py", line 226, in _send_receive
raise e
File "/config/custom_components/localtuya/pytuya/__init__.py", line 211, in _send_receive
data = s.recv(1024)
File "/config/custom_components/localtuya/cover.py", line 89, in setup_platform
TuyaDevice(
File "/config/custom_components/localtuya/cover.py", line 169, in __init__
File "/config/custom_components/localtuya/cover.py", line 152, in status
File "/config/custom_components/localtuya/cover.py", line 126, in __get_status
A few more pieces of information:
I’m running Home Assistant w/Supervisor on a Raspberry Pi 4
My Raspberry Pi’s IP is 192.168.1.56
My cover device’s IP is 192.168.1.29
The requisite port (6668) is open
Again, any help would be so greatly appreciated.
If your devices require to work with the “light” integration instead of “switch”, I am afraid that you or somebody else needs to adapt my work for that. I forked from milesperhour and never touched the light.py code since I don’t have any of those devices so I could not test if the code works; and also in pytuya there are some references that need to be adapted. I also noticed that light.py still refers to the old version of pytuya (7.0.4, now should be 7.0.8).
Sorry for not being more helpful but as you can imagine it’s hard to code without the hardware to test.
Mmm, this is strange. I have some covers (different from yours), and took a long time to make them work but finally did the job. I also couldn’t make them work with tuya-cli, I get a ‘json obj data unvalid’ error, so I had to try something else to make them work.
Yours should definitely work with my localtuya, we just need to figure out what’s going wrong. Your enhanced debug is very clear and it looks that your request is well formed, however the device does not respond and you get a timeout: we need to investigate why this is happening, since the configuration seems correct and you get it working with tuya-cli setting protocol=3.3.
I believe you are very close to make it working, if you want I can send you a little command line script that I use to debug and write code that may help you debug faster, since you don’t need to reboot HomeAssistant every time. It might be helpful also for @OfWonder but he would need to edit a lot for lights to work.
Let me know, bye
rospogrigio
@rospogrigio If I were to mail you one of the switches, would you be able to work on the code? I have an extra one because one of the switches in my house didn’t have a neutral wire.
@OfWonder One cheaper and quicker option would maybe to give me access to your system so I can try to debug remotely, but I will do it in my spare time (which is not much since I have a 2 yo daughter ) so I cannot guarantee on the timing.
Write me in pvt in case,
rospogrigio
@rospogrigio thanks so much for the quick response. Yes, please do send me the command line script you use to debug, that would be great.
Cheers
