yes app always works, I am using smartlife
For a while I had both Local Tuya and Tuya V2 running in HA to see what sensors were available - so yes.
DUDE! I cannot thank you enough. I’ve been pulling my hair out on these for a month and as soon as I plugged THIS magical combination in, everything started working properly!
I finally have more than just on/off
The TuYa TV02-Zigbee is a device using the Zigbee protocol (not WiFi). Thus you will need the Zigbee2MQTT integration and a Zigbee-Adapter on your HA to be able to manage the device. Tuya Local will not work with the TuYa TV02-Zigbee.
Under localtuya repository, there is an open PR to add child ZigBee devices over localtuya integration.
Hi guys,
I check all thread but looks like nobody have come across this which is a bit strange…
Anyway, just got an outdoor siren that, as far as I am able to understand, does not have a simple “alarm on/off” switch -it rather has a few options to select, like this:
I am struggling to find a proper platform in local tuya integration that would allow me to choose on of those options. If I choose “select” as a platform - it only let me specify two options but not more:
Any ideas how to overcome that? Do I need to choose any another platform or this type of device is not supported (yet) ?
Thank you
P.S. And “select” platform does not work anyway… it is just grayed/disabled in HA so I must choose something else… but what?
I am using switch platform. I am using 104 as main switch, 105 as current and 106 as voltage.
I mapped main switch as alarm trigger switch.
Current value as temperature sensor and voltage value as humidity sensor.
Mine is supporting these.
To answer my own question - I have not found a solution to my problem yet while using LocalTuya integration.
However there is a workaround. I user tinytuya python module to write my own little script that sends exactly what I want to the siren.
HA can either call the script directly or use MQTT to send a command to my server where the script is. For now it is one way communication (HA can only send commands to the siren but not read its state back) but I don’t think this is a problem - the siren is not a sensor anyway.
I know this is old, but how exactly does the select entity work?
How do I input this in the setup dialog?
Fan support is still broken since HA update? My two fan controllers don’t change fan speed, error popup every time. Though i can turn on/off it.
I played with this device (Moes Wake Up Light II) 3 weeks ago. Then I was able to define 19 parameters. Only 9 have been available for the last few days. Probably there was an upgrade . There is an interesting video on this topic on yt: Adding Local Tuya Devices (Dekala Arkenstone Lamp) - YouTube
Hello Everyone,
Just wanted to ask if there is support of Switch Dimmers in Local Tuya? Specifically, i am interested to get this one: New WiFi Smart Touch Light Dimmer Switch Timer Brightness Memory EU — MOES
I am expecting to see 2 entities in Home assistant, one for the switch, and one for the brightness.
Is this supported in Local tuya?
Thank you very much
Kind Regards
Should I put in a PR for this change so the Atomi lights don’t break each time there’s a Local Tuya update?
SCENE_LIST_RGBW_255 = {
"White": "white",
"Color": "colour",
"chase": "scene5",
"America": "scene7",
"Fade": "scene2",
"Pulse": "scene3",
"Blink": "scene4",
"Christmas": "scene6",
"Pick 2": "scene8",
"Rainbow": "scene9",
Any idea of supporting this dimmer?
Bump, I’m trying to do the same. I now get that the Arlec has a series of states as per below.
101 - Mode: mode_auto/mode_on/mode_off
102 - Light State: true/false
103 - Motion Sensitivity: [0-4]
104 - Light Timeout when in Auto mode (secs)
105 - Light Cutout Threshold [0-3900]
106 - Reset to Auto after 1 hr in Manual On: True/False
So what I understand is to turn on the light I need to send the device a ‘select’ of mode_on.
How do I send a select?
Have a look at the data point tables towards the bottom of the page. It took me a little to figure out but using the descriptions next to the data IDs should help
Thanks, works a treat!!
#!/usr/local/bin/python
import tinytuya
d = tinytuya.OutletDevice('DEVICE_ID_HERE', 'IP_ADDRESS_HERE', 'LOCAL_KEY_HERE')
d.set_version(3.3)
#data = d.status()
#print('set_status() result %r' % data)
d.set_value(101, 'mode_on')
I am on the HA beta for 2022.6 and I’m starting to receive some warnings of things to come with this integration:
Logger: homeassistant.helpers.frame
Source: helpers/frame.py:103
First occurred: 8:25:47 PM (1 occurrences)
Last logged: 8:25:47 PM
Detected integration that uses deprecated async_get_registry
to access entity registry, use async_get instead. Please report issue to the custom component author for localtuya using this method at custom_components/localtuya/init.py, line 315: ent_reg = await er.async_get_registry(hass)
