I have a Tuya MCU fan that I transplanted an ESP8266 into. I was able to get everything working fairly easily with the exception of the fan speed.
I’m not sure if the fan speed is datapoint 2 or 3 at the moment; I suspect 3 because when I use 2 it changes the “mode of the fan” between natural, sleep and normal, but does not change the speed. When using datapoint 3 I get nothing.
After doing some research I believe this is because the fan is expecting an integer and by default HA is throwing it a percentage. I was looking into using Lambdas as this seems to be the way to go to send integers but I’m just lost at where to begin. I’m hoping someone can point me in the right direction based on my code here. Thanks!
esphome:
platform: ESP8266
board: esp01_1m
wifi:
ssid: ""
password: ""
ap:
ssid: "Arlec Tower Fan Hotspot"
password: ""
api:
ota:
web_server:
port: 80
logger:
# Disable UART logging as these pins are used for Tuya MCU comms
baud_rate: 0
uart:
rx_pin: GPIO03
tx_pin: GPIO01
baud_rate: 9600
tuya:
fan:
- platform: "tuya"
name: Living Rm Fan
switch_datapoint: 1
speed_datapoint: 2
oscillation_datapoint: 5
speed_count: 4
- platform: "tuya"
sensor_datapoint: 21
name: "Living Rm Temperature"
- platform: "tuya"
sensor_datapoint: 23
name: "Time to off"
