Tuya Neo Zigbee Siren TS0601 setting melody via cluster attribute does not change melody
Using ZHA the melody attribute is not exposed. I have found it under clusters - TuyaMCUSiren - melody (id: 0x0466).
I then clicked Read Attribute and it returns a value of NeoAlarmMelody.melody_05.
I changed this to
NeoAlarmMelody.melody_01
and then clicked Write Attribute
Succeeds with a green tick
But the siren melody does not change
Is there something else I need to do?
I have never set a cluster attribute for a ZHA device before.
Hi, do you change the melody under “value” or under “Manufacture Code Override”?
i also have a “TuyaMCUSiren” with the same id 0x0466 and it is working when i cange the paramter under “value”.
i tried it some hours with the “Manufacture Code Override” and it also gives me a green tick
 but it was not working :wink:
I tried changing value as well.
What did you put in the value field? An integer like 3 or 4 or 5
Or something else
yes, i just changed the 05 to 04, 03 and so on
default was:
changed to:
NeoAlarmMelody.melody_06
and clicked: “write attribute”
So if you are interested in this topic, there is a way to change Tuya settings on the fly. There is a service ‘zha.set_zigbee_cluster_attribute’ that is very useful. What you need is the Tuya ieee, the end point, the cluster id, and the attribute id. All you can find by going to
  • ‘Settings’ → ‘Devices and Services’, clicking on ‘Zigbee Home Automation’.
  • Then click on ‘x Devices’ (x depends on the number of devices you have) and
  • from the resulting list selecting your Tuya device.
Click on the little down-arrow next to ‘Zigbee info’ and presto: you have your IEEE. Copy that.
  • Click pin the three dots in the ‘Device Info’ box
  • Choose ‘Manage Zigbee device’ option.
  • Click on the ‘Clusters’ list, choose ‘TuyaMCUsiren’.
You now have your cluster-id and end point next to ‘TuyaMCUsiren’. Cop that. They are in hexadecimal so you need to convert to decimal (lots of websites will do that for you).
We’re close now, just need the arrtibute id.
  • Click on ‘Attributes of the selected cluster’ and you see what you can set.
There’s volume, melody and alarm_duraction. Copy their id’s (in the drop down list) and convert to decimal.
Once you have all that, the service is (with my data):
  - service: zha.set_zigbee_cluster_attribute
      cluster_type: in
      ieee: a4:c1:38:2a:ed:24:14:9c # Yours WILL be different, use yours
      endpoint_id: 1  # (probably right but yours may differ)
      cluster_id: 6.    # (probably right but yours may differ)
      attribute: 1126  # (probably right but yours may differ)
      value: 6 # melodies 1 to 16 - try them out yourself (10 is dog barking)
A nice way to do this is to make a script, get into YAML mode, delete what’s there and paste the below (adapt as needed). Then try using it in an automation
 too easy really :wink:
SCRIPT YAML:
alias: Sound siren
fields:
  siren:
    description: Siren sound
    selector:
      select:
        options:
          - label: warning
            value: '8'
          - label: pending
            value: '16'
          - label: alarm
            value: '6'
          - label: alarm2
            value: '11'
          - label: dog
            value: '10'
    default: warning
    required: true
  volume:
    description: Siren volume
    default: low
    required: true
    selector:
      select:
        options:
          - label: low
            value: '0'
          - label: medium
            value: '1'
          - label: high
            value: '2'
  duration:
    description: Siren duration (s)
    default: 10
    required: true
    selector:
      number:
        mode: box
        unit_of_measurement: seconds
        min: 1
        max: 59
sequence:
      cluster_type: in
      endpoint_id: 1
      cluster_id: 6
      attribute: 1126
      value: "{{ siren }}"
  - delay:
      hours: 0
      minutes: 0
      seconds: 0
      milliseconds: 30
      cluster_type: in
      endpoint_id: 1
      cluster_id: 6
      attribute: 1140
      value: "{{ volume }}"
  - delay:
      hours: 0
      minutes: 0
      seconds: 0
      milliseconds: 30
      cluster_type: in
      endpoint_id: 1
      cluster_id: 6
      attribute: 615
      value: "{{ duration }}"
  - delay:
      hours: 0
      minutes: 0
      seconds: 1
      milliseconds: 0
  - service: switch.turn_on
    data: {}
      entity_id:
        - switch.alarm_siren_group
        - switch.indoor_siren_switch
mode: single
icon: mdi:bugle
