Hey all,
I am having trouble getting the Tuya integration working properly. I had this set up a couple of months back, and it worked ok at the time, but then the two bulbs I had set up were not being used until we finished remodeling the room they go in.
At the time, I followed the steps in this article:
I have both bulbs set up in the Tuya app and can control them fine from there.
Set up an account on the Tuya IoT platform and have the integration configured with the correct client ID and secret, devices added and showing up as expected there as well.
On startup, the Tuya integration is reporting “Failed to set up,” and obviously the devices are not responding in HA.
Relevant log lines follow:
2021-12-07 15:37:04 ERROR (MainThread) [homeassistant.config_entries] Error setting up entry [email protected] for tuya
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 304, in async_setup
result = await component.async_setup_entry(hass, self) # type: ignore
File "/usr/src/homeassistant/homeassistant/components/tuya/__init__.py", line 63, in async_setup_entry
success = await _init_tuya_sdk(hass, entry)
File "/usr/src/homeassistant/homeassistant/components/tuya/__init__.py", line 75, in _init_tuya_sdk
auth_type = AuthType(entry.data[CONF_AUTH_TYPE])
KeyError: 'auth_type'
I thought I would delete and reconfigure the integration, but now I cannot even get the Client Secret. When I try to view the Client Secret, I am presented with the following message:
AGH! DO NOT WANT. This happens whether I am looking to view the Client Secret for an existing Cloud Project or if I am creating a new one.
I know there were some changes to the way Tuya integrations work recently, I am running core-2021.11.5.
