Hi all,
I have Zigbee2MQTT up and running - and am trying to get Tuya PA-44Z Smoke Detectors up and running.
They are being discovered and show as supported - but they are failing to display most of the important entities. All that I can see is battery, test and link quality.
There should be additional entities - including, importantly, ‘smoke’.
https://www.zigbee2mqtt.io/devices/PA-44Z.html#tuya-pa-44z
Has anyone potentially had a similar issue and solved for it?
Cheers
